Replacing Base Model Struts/Shocks with Sport Suspension Struts/Shocks??
Old Oct 16, 2012 | 04:03 PM
ehaglund's Avatar
Default Replacing Base Model Struts/Shocks with Sport Suspension Struts/Shocks??
Hey guys-- is it possible when replacing my High Series 2004 X Type (w/3.0L) front struts to order replacement struts (w/sport suspension) instead of the base model (w/o Sport Suspension)??? Is the sport suspension strut just a bit stiffer ride, or are there other physical differences in the actual part?
The reason I ask is because the struts and shocks for X Type vehicles with sport suspension are cheaper than the base model struts and shocks... go figure?!!?
Thanks in advance for your assistance!
Old Oct 16, 2012 | 05:55 PM
disguay's Avatar
Should just be a stiffer ride. Nothing different with mounting at all. Same physical part, just different internals.
Old Oct 16, 2012 | 07:03 PM
Thermo's Avatar
Veteran: Navy
ehaglund, should work, but also keep in mind that the sport model X-Types sit 1.4" lower than non-sport versions. So, upward travel is not much of an issue, but you may find that shock damage may occur if say you hit a pothole and the wheel is allowed to go to full travel down. Something to think about. It may be one of those things that you would need to give Bilstein a call and see if the overall dimensions of the shock are the same (ie, full extension length, full compression length) a the only difference is the valving.
Old Oct 18, 2012 | 11:29 AM
ehaglund's Avatar
Thanks Guys!
philwarner
Dec 6, 2021 07:13 AM
Fraser Mitchell
Oct 1, 2015 04:06 AM
duprey26
Sep 8, 2015 05:28 PM
martybmw
Aug 31, 2015 08:41 AM
aquifer
Aug 29, 2015 04:54 PM
