reset engine light
Old Sep 26, 2014 | 04:08 AM
fzx's Avatar
fzx
Default reset engine light
hi guys please help me!
my X-Type( left hand yom december 2001, 2500cc) still works and looks very very good...but the engine lights won't reset....
after fix the cruise control(just using an elettronical splay cleaner) i can't reset the dash light....must i buy a cheap OBD2 or you can suggest another way to reset it????
i try to disconnect battery for one day and others suff...don't works!
ps) burning the car is impossible, using a big heavy hammer too!!!
Old Sep 26, 2014 | 06:13 AM
Dr dome's Avatar
The only way to reset is to use the obd2. They are cheap enough at the local parts store near you.
Good luck,
The Dr
Old Sep 26, 2014 | 10:12 AM
Thermo's Avatar
Veteran: Navy
fzx, if you have pulled the cables off of the battery and ten reconnected them and still have the light, then you have not fixed the problem. The car is still seeing the problem. The light will remain on till the computer thinks the problem is not there. What code(s) are you getting? That may help us come to a solution for you.
I would recommend that if you have an android based phone, to do some looking into an "ELM 327" unit. They make them in a bluetooth version and for the $15 and a free app, it is really hard to beat what it offers to you.
Let me know the codes and we can get you back up and running without the CEL being on.
Old Sep 26, 2014 | 05:25 PM
liquidreality's Avatar
I second that,I think mine was 12 shipped on Amazon.
Do you use "torque" thermo?
Old Sep 27, 2014 | 02:31 AM
fzx's Avatar
fzx
thank's guys for your answers...
i'was thinking about this
D900 Any Car OBD2 EOBD CAN BUS Fault Code Reader Scanner diagnostic scan tool UK | eBay
but now ask my son for elm 327...it's very interessing!
i'm too old for modern engines!
Old Sep 27, 2014 | 09:35 AM
Thermo's Avatar
Veteran: Navy
Liquid, yes, I use the Torque program. If I get my new XJL, then I am going to get the new ELM unit to match up to the new system and then spend the extra $5 to register the program. That way I can start doing some dyno runs. I have a few "ideas" in my head for what I want to do. It will be curious to see what sort of changes I can make happen. He he he he.
Old Sep 27, 2014 | 09:36 AM
Thermo's Avatar
Veteran: Navy
fzx, for what that code reader does that you are looking at, you would be much better off getting a cheap used android phone (no need to get cell service for it, you just want it for the bluetooth ability unless you have a laptop with bluetooth capability) and the ELM box. You will have a lot more features available to you for about the the same price. The ELM unit will give you real time data of the engine which if you are a motor head, can be very useful in figuring out what is truely wrong.
Old Sep 27, 2014 | 12:47 PM
I was hoping you already had the pro version. I am having trouble getting itdo hp/torque and 0-60 calculations, and I was wondering if it was a limitation of my adapter oritorgif thehe ecu itself, or of
if I'm just an idiot that doesn't know how to get the test to start
toronadomike
Jan 22, 2026 10:13 PM
JarodL
Mar 7, 2024 01:39 AM
D.K
Dec 10, 2023 02:05 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
TC Johnson
Sep 2, 2015 09:30 AM
