Rim offset question
Old Sep 12, 2016 | 06:47 PM
iownme's Avatar
Default Rim offset question
Im looking at a new set of 17x108
Rims
I use 17/45/235 tires
The offsets offered are 20mm or 40mm.
I like my wheels to stick out as far as possible.
Which offsets can i use, and which will give me the look i want?
Old Sep 13, 2016 | 07:05 AM
Thermo's Avatar
Veteran: Navy
iownme, the 20mm is going to stick out farther than the 40mm offset. The question comes whether you will get tire rub with the 20mm offset rims. Also keep in mind that the 20mm rims are going to put more stress on the hub assemblies as the tire stresses will not be inline with the hub bearing any more. There will be more of a twisting effect (ie, the top of the tire is going to want to pull out to the side more). Will this cause the hub to fail in 1,000 miles? Probably not. Shorten its life by say 30K miles (from say 100,000 miles to 70,000 miles), probably a good chance.
Not saying that you shouldn't. Just pointing out what the possibilities are to what you plan on doing.
Old Sep 15, 2016 | 04:13 AM
iownme's Avatar
Thankyou Thermo.
I'll probably go with the 40mm just to be "safe" (or old..lol)
Old May 27, 2020 | 07:37 AM
Phil Edwards's Avatar
Posted in error
garysaunders85
Mar 26, 2019 09:27 AM
GMaxima
Jul 8, 2016 02:43 PM
XxSlowpokexX
Jun 11, 2015 08:14 PM
Qgregg
Mar 26, 2012 02:34 PM
Knaych
Mar 9, 2009 12:17 AM
