Rough idle at startup
Old Feb 5, 2008 | 11:08 AM
morales8416's Avatar
Default Rough idle at startup
Afternoon ladies and gents
2002 3.0 when engine is cold idle is rough for the first 3 min or so until engine gets some temp. Any idea's thanks. No fault codes
Old Feb 5, 2008 | 02:48 PM
aquill1's Avatar
Default RE: Rough idle at startup
Check underneath the plastic in your engine bay...remove the 4 screws pop it off (after removing the oil cap) and you should see a hose running front to back that may have a crack in it...this was my problem but it didn't trigger any lights for a couple of months.
Old Feb 5, 2008 | 06:17 PM
FactoryJaguarTech's Avatar
Also check the IMT seals to the left (in the pic) rear of intake manifold.
Also the grey plastic check valve from the brake booster to the intake manifold. All very common sources of vacuum leaks and rough running.
Old Feb 5, 2008 | 08:28 PM
aquill1's Avatar
If that hose is the culprit you'll notice why right away the tube looks really really really bad! Pretty much a slice from front to back of that black tube/hose!
Old Feb 6, 2008 | 11:16 AM
thanks for the advise checking it out today
Old Feb 6, 2008 | 05:54 PM
310jag's Avatar
Most likely the aforementioned hose, especially if it's never been replaced. Mine had a nice 5" slice in it, clean as a razor blade. The replacement from Jaguar is much thicker, and is ribbed (for her pleasure). heh.
Old Feb 6, 2008 | 06:05 PM
Thats precisley why we just go to the parts dept. and ask for 2 imt seals and a ***** hose.
Old Feb 6, 2008 | 09:19 PM
jhe2003's Avatar
There is also a few TSBs about rough idle and some misfire codes on early VIN X Types, some require a software upgrade, if you have access to a scan tool check your Long Term Fuel Trims, if above 7-8% then I might be looking for anair leak or vacuum leak,
Old Feb 7, 2008 | 03:14 PM
billinohio's Avatar
would you(fjt) if possible with aquills picture, draw an arrow to the imt seals and the other vac hose to check? i'm kinda inclined but have no idea where these hoses are. thaks, Bill
Old Feb 7, 2008 | 06:37 PM
Dennis's Avatar
ud
Here is the Intake Air Control Valves (IMT)
Old Feb 7, 2008 | 06:57 PM
Yup those are the imt valves. The other hose runs from the brake booster to the intake manifold. It has a big round grey check valve in the middle of it. It is about 8 inches long, (the hose that is).
Old Feb 9, 2008 | 09:32 PM
IMT SEALS AND A BAD HOSE THANKS GUYS RIGHT ON THE MONEY
Old Feb 10, 2008 | 08:25 AM
Nice to know another X is going to prowling the streets healthy again.
Old Feb 10, 2008 | 09:23 AM
ibjags's Avatar
we replace the complete brake booster pipe, valve is part of the pipe
i have seen independants use heat shrink around the check valve
no brakes and also a brake pressure transducer fault can occur as well
Old Feb 10, 2008 | 10:12 AM
Like he said. Beforecthe brake problems, you would normally feel rough running. You can normally hear the vacuum leak also.
The brake problem would first be evidenced by hard pedal due to lack of vacuum assist.
Old Feb 13, 2008 | 12:39 AM
RedDucati's Avatar
I gotta say this thread help me a lot .saving me money and sanity.now the check engine that has been there for 6 mos. is gone.all because of a damn hose and a couple of $4 part. Thanks everyone.
Old Feb 13, 2008 | 03:55 PM
aquill1's Avatar
Good to hear ducati so you also had the hose problem?
Old Feb 13, 2008 | 06:26 PM
IMT is Induction Manifold Tuning. They are basically just a butterfly valve that allows air to flow at a different rate based on engine load. Full throttle, wide open valves. Personally I have disconnected them electrically and saw no difference in the way the car ran.
Sorry for the late reply Bo.
Old Feb 15, 2008 | 06:44 PM
ruslan35's Avatar
Do you guys know if this is BAD?: when i opened my Intake Air Control Valves, i saw some oil inside. Dodnt know if that is a good thing or not.
My car is also running rough on cold weather start and i can hear weasling noice when driving in the begining. Also a stiff brake pedal for the first minute after start.
Will check brake booset vacuum hose tomorow.
