Running rough at idle
Old Jul 17, 2017 | 03:56 PM
jgarton_2007's Avatar
Default Running rough at idle
I have a Jaguar X-Type 3.0l sport manual petrol that runs rough when idling. Also when you go to drive it there is no power and sounds really rough and will cut out.
Old Jul 17, 2017 | 05:01 PM
JagV8's Avatar
Check fuel trims / for air leaks.
Old Jul 18, 2017 | 06:35 AM
iownme's Avatar
when was the air filter last changed?
check to see if it needs to be replaced.
clogged filter will cause that and is the 1st thing to check
Old Jul 19, 2017 | 07:25 AM
iownme's Avatar
also replace the fuel filter.
easy
cheap
a likely suspect too
Jag-o-nomic
Feb 15, 2017 04:06 AM
legog
Feb 6, 2017 08:43 AM
TGman
Nov 8, 2016 09:21 AM
tr_car_nut
Jan 20, 2009 05:44 PM
stypeguy00
Aug 28, 2008 02:31 PM
