Sat Nav has lost its voice
Hello all....
Mt fully functional Sat Nav system has recently lost its voice. This happened after fitting an ISimple IS31 system. Ths IS31 is a simple antenna bypass system, i checked during installation that the sat nav worked with voice and it did, now it doesn't! I have checked all the audio setting and everything is fine and set correctly, radio works fine etc.
I did disconnect the ISimple setup and tried the original setup but still no voice.
I was prompted for the radio code on starting up, which i have and this all worked.
Is it worth disconnecting the battery, if i go into the deeper audio menu is there anything i can check there or indeed elsewhere?
I have had the rear bumper of recently to fit a towbar and i did have cause to move the CD/Sat Nav system (Not disconnect) when i dropped a bolt underneath the mounts. Is there anything obvious worth checking there? All leads seem to be connected.
Any advice greatly received.
