Seat Heater..checked fuses
Old Jan 11, 2010 | 07:20 PM
Strafe's Avatar
Default Seat Heater..checked fuses
My drivers side seat heater is out. I've checked all the fuses. Passengers is fine.
Am I missing something or is there anything else I can check before having to take it in?
Thanks!
Old Jan 11, 2010 | 08:09 PM
Thermo's Avatar
Veteran: Navy
Strafe, first, check fuse F66 and F77 to see they it are good. Next, locate the seat heater control module and locate the white wire coming off of it (terminal #9). Connect a multimeter to this wire (red lead) and chassis ground. With the multimeter taking a resistance measurement, press the button to engage the seat heater (ensure the ignition switch is in the RUN position, aka II position). Did the multimeter drop to under 5 ohms when the button is depressed? If no, then you have a bad pushbutton or wiring issue between the control module and the switch. Repeat at the switch to differentiate.
If the switch did drop to less than 5 ohms, switch the multimeter over to do a voltage measurement and connect the multimeter to the green/black wire (red lead) at terminal 6 and the black wire (black lead) at terminal 7. Now, with the seat button pressed one time to enter the high heat setting, does the multimeter jump to over 10 VDC? If yes, then you have a bad seat element. if it does not, then you have a failed heater control module.
This should get the system up and running again.
Old Jan 12, 2010 | 08:42 PM
Strafe's Avatar
where's the heater control module?
Thanks!
Old Jan 12, 2010 | 10:08 PM
Thermo's Avatar
Veteran: Navy
Strafe, it is under the driver's seat. Undo the 4 bolts holding the seat down and you can access it there.
Old Jan 14, 2010 | 09:13 PM
Strafe's Avatar
Thanks Chris! I''m gonna tackle it this weekend.
Old Jan 15, 2010 | 05:27 PM
Thermo's Avatar
Veteran: Navy
Strafe, if you need any help, give me a call, I have a phone number in the Norfolk, VA area (757 area code). Should be a cheap call for you. Worst case, I'm 2 hours away in southern MD.
Rivguy
Nov 13, 2022 02:55 AM
hamilton7550
Jul 30, 2021 11:29 PM
r111ynf
Sep 20, 2015 09:42 AM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
tvholden
Sep 12, 2015 11:13 AM
