shift solenoid
Old May 27, 2014 | 12:11 PM
fourbyfourbyfar's Avatar
Default shift solenoid
does anybody know the part no. for the 4th gear shift solenoid as my main dealer says it all comes complete with the j gate and it doesn't look like what i need
Old May 27, 2014 | 03:04 PM
ltmax's Avatar
The shift solenoid is inside the transmission valve body not in the J-Gate shifter. You may want to take it to a trans shop and have them look at your reverse/high clutch piston as they are the number one failure item on these transimssions and can be fixed with the trans still in the car.
With a diagram of the transmission wiring you can easily read the resistance of all the shfit solenoids to see if any are bad but I doubt that is actually our problem. Let me know if you want a copy of the diagram.
Old May 27, 2014 | 03:57 PM
i thought he was wrong with part i needed would the reverse/high clutch piston cause my problem 4th gear not engageing when accelerating a bit hard but ok when gently accelerating i've got no fault codes for the gearbox see my other post on auto trans fault
Old May 27, 2014 | 04:25 PM
ltmax's Avatar
I'm not exactly sure, but that is the most common problem these Jatco transmissions have and loss of pressure due to fluid leaking from a cracked piston inside the transmission can cause all sorts of problems.
If it were me, I'd try and service it with some new fluid and a bottle of Lubegard Platinum trans additive in the fluid and see if that helps at all. Every transmission shop and re-builder I know swears by the stuff.
Old May 28, 2014 | 12:34 AM
took the car out last night and no problems all gears fine it only affects 4th if you send me a copy of the wiring diagram that would be great as i have a jaguar manual from jagdocs but it doesn't have wiring diagram is that lube available over here ?
Old May 28, 2014 | 02:18 AM
ltmax's Avatar
Here you are. The Lubegard is available online ebay should have it. Good luck!
File Type: pdf
File Type: pdf
hkmcmast
Nov 29, 2015 06:56 AM
Johnken
Oct 2, 2015 10:12 AM
hughey
Oct 2, 2015 05:17 AM
dansxj6
Sep 28, 2015 08:02 AM
