Shifter won't go into park
Old Sep 11, 2010 | 09:42 AM
Topdawg82's Avatar
The first thing that I would try is adjusting your shift cable. If you look at the trans where that cable connects(under the car) there is a shield with three 8mm bolts. Take the shield off and you'll see the cable and there will be a 8mm bolt going through the cable. Put the shifter in neutral(they make a tool to hold it there, but you can have someone hold it). Then loosen the bolt on the cable. I usually shake the cable a little with the bolt loose and the cable adjustment should move to where it needs to be. Then just tighten the bolt on the cable and you should be set.
neruda
Oct 18, 2015 01:19 PM
Roger95
Sep 25, 2015 02:05 PM
Road Racer
Sep 19, 2015 04:08 AM
Road Racer
Sep 17, 2015 06:53 AM
Doovoe
XJ40 ( XJ81 )
Sep 6, 2015 10:54 AM
