Shuddering on acceleration 55-70mph
Old Jun 28, 2019 | 05:10 AM
v8steve's Avatar
Angry Shuddering on acceleration 55-70mph
Hi. I have a 2008 X Type 2.0 D which has started shuddering on acceleration, when maintaining speed the shuddering goes away but can also be felt when engine breaking.
I had it up on axle stands running and the drivers side wheel appeared to have a slight buckle in it so I swapped the wheel for the spare and the problem has not been cured.
I am suspecting it could be drive shaft/CV related but cannot see any play in it, I have had it into a garage who also cannot find anything wrong with it either, they suggest letting it get worse, however I am cautious of doing this as I dont want anything else being damaged by the vibrations/something running excentric.
Has anyone had a similar fault and got to the bottom of it?
Old Jun 28, 2019 | 09:28 AM
Thermo's Avatar
Veteran: Navy
V8Steve, if you have an AWD car, then I would be looking at the carrier bearing on the rear driveshaft. This has been known to cause vibrations in the speeds that you are talking about. If you have a FWD car, then I am not sure what to tell you.
Old Jun 28, 2019 | 11:17 AM
XJ8JR's Avatar
I had something very similar which turned out to be the transmission mount.
Old Jun 30, 2019 | 01:20 AM
v8steve's Avatar
Hi. Thanks for your replies, it is FWD not AWD.
I have had it up on lift at another garage to look at it again and the drivers side drive shaft seams to be running slightly eccentric, I've ordered a new drive shaft, hoping that solves it, clutching at straws now with it.
Old Jun 30, 2019 | 01:26 AM
v8steve's Avatar
I'll have a look at transmission mount when it's up in air, do you know if it was an obvious failure or a crow bar job to find excessive play in it? Was your car FWD?
Old Jun 30, 2019 | 02:08 AM
Dell Gailey's Avatar
Check the "dogbone". This Is a mondeo replacement, but same process (and part) for the X.
Old Jul 2, 2019 | 04:38 AM
v8steve's Avatar
UPDATE - PROBLEM SOLVED
The Culprit : Drivers side driveshaft, appears to be inner CV joint that is the problem, there is lots of backlash in the inner CV joint, everything else on the driveshaft appears to be okay.
Thanks to everyone for suggestions.
nzpete81
Feb 15, 2018 08:05 PM
srteague
Oct 28, 2012 09:48 AM
amcdonal86
May 30, 2011 08:15 AM
msobug
Jul 24, 2009 10:14 PM
