Sick of Reading!!
Old Jan 24, 2009 | 12:53 PM
adreasx's Avatar
Default RE: Sick of Reading!!
OK, we're almost there. When you did the fluid change, did you get all of the old stuff out, or did you mix the new Dexron in with the old fluid? If you did get all of the old fluid out, how'd you do it? Thanks good buddy.............
Old Jan 24, 2009 | 01:23 PM
christo's Avatar
I hear ya, the search does not go back more than a year and searched 6 ways to sunday for posts started by racerx?
Old Jan 24, 2009 | 05:06 PM
MarkC's Avatar
ORIGINAL: Dennis
No pan, no magnets, no filter..on the JATCO..and no dip stick
Have any of you AT guys installed an in-line filter?
http://www.emergingent.com/subpage1Magnefine.htm
Old Jan 24, 2009 | 06:43 PM
Real_Tech's Avatar
The drainplug is magnetic.
Old Jan 24, 2009 | 07:27 PM
racerx82's Avatar
Wow...you all must be real TIRED OF READING. Because........if you read THIS post, it pretty much tells YOU how to flush the system.
Geeeze....i write a book, then i have to explain it ! lol
Old Jan 24, 2009 | 11:24 PM
Dennis's Avatar
ud
What post would that be?
Old Jan 25, 2009 | 08:13 AM
christo's Avatar
I think I found it, but we should let racerx confirm it - this was in the S-Type section...
https://www.jaguarforums.com/m_5794/tm.htm
Old Jan 25, 2009 | 10:42 AM
  #28
racerx82's Avatar
Ya, works for me....
Must have been one of my sober nights posting...
Old Jan 25, 2009 | 10:49 AM
JagXV6's Avatar
I have only been here since Aug. of 2008 so he posted it last fall. Apparently RACERX had
been away for awhile then came back. Dennis asked him how he does it and he posted
it here in X-Type forum. But the info in S-Type forum is essentially what he posted.
Old Jan 25, 2009 | 11:26 AM
  #30
racerx82's Avatar
Thanks for that explanation...
how long was i out for?
Old Jan 25, 2009 | 12:22 PM
  #31
christo's Avatar
I don't knw how you you were away for, all I know is when you came back, this forum was very happy you did. I am still trying to read up from your very 1st post but I can not find anything before 1/1/07 - I would really like to see you x-type and read those posts... Looks like you joined back in 2004...
Does anyone know how to get into the archives with the search feature?
Old Jan 25, 2009 | 12:56 PM
  #32
Dennis's Avatar
ud
ORIGINAL: racerx82
Okay Buddy..you have me completely confused again...
When its done close the plug, and pour in fluid from above. The plug should be between the battery and the throttle body/airbox area, down in there. I was able to weasle my hand down between the battery, airbox, and front of the car and pop the plastic plug off. People with big hands will need to move the battery.
At one time many posts ago, you told me that you opened the big hex plug (allen)on top of the tranny behind the battery to pour in your ATF..this quote from you above says to pop the cork like I thought as explained in the JTIS (it's called a charging port)when we were discussing this long ago andI humbly conceided to your way, by removing the big HEX (allen) plug..so which is is it now..???[&:]
Thanks buddy
Old Jan 25, 2009 | 03:20 PM
  #33
racerx82's Avatar
lol
Relax, i was told (back then) the some model years had the hex plug and some had the cork thing. My 05 had the hex.
Old Jan 28, 2009 | 02:29 PM
  #34
Dennis's Avatar
ud
I am relaxed, damit!!![:@]..You didn't bother explaining that back then..just left it hanging and claimed I was messing with a vent....common..share ALL that you know, not just tid bits to keep us guessing.
All Xtypes yearshave both...Cork and hex plug
Old Mar 10, 2012 | 06:42 PM
  #35
pmcnic's Avatar
I have changed my Trans Fluid 6 times in the last year in an attempt to flush out all the old fluid. I was getting some harsh 1st to 2nd shifts in slow traffic. At first I was using Valvoline Maxlife Dex/Merc. Big improvement over the old dirty fluid. Then I switched to Mobil One synthetic ATF. The Mobil one has a little higher viscosity then the Valvoline. The next time I change the fluid I may try the Pentosin ATF 1, or the AMSOIL Synthetic Multi-Vehicle Transmission Fluid. Pentosin e-mailed me that they meet the jaguar spec and Amsoil list it on there web site.
Has any one used the Idemitsu Lubricants Automatic Transmission Fluid Matic-J ATF. I have recently found this on a couple of web sites listing it for Jaguear x-type.
philwarner
25
Jun 26, 2021 05:43 AM
Broken_Spanners
Dec 11, 2015 04:14 AM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
explorer364
Sep 14, 2015 07:43 PM
Dickie_L_J_O
Sep 13, 2015 07:44 AM
