spark plug question
Old Oct 24, 2012 | 06:36 PM
Wahooesprit's Avatar
Default spark plug question
Hello
I'm going to change the plugs on my x type and was wondering if all I need is
1) plenum gaskets
2) throttle body gasket
3) pcv valve
looks just like my '95 probe gt motor to pull the intake off..
bought some ngk iridiums for her (run them in the lotus, porsche, S2000)
also putting the rockauto drilled/slotted rotor kit on it...hope it looks good with the "new" arubas...
if only I could post a pic from my iphone to this site....computer challenged? yes-- but that is why I have teenagers around...
Old Oct 24, 2012 | 10:07 PM
disguay's Avatar
Technically you don't even need the throttle body gasket!
When I changed my spark plugs I just did the plenum gasket and the spark plugs but that was because my throttle body gasket was somewhat new. What I would recommend highly is getting some IMT o-rings for the manifold tuning valves because with the intake manifold off, you can actually get to them. I threw codes about 2000 miles after my spark plugs because I didn't change my IMT o-rings and I ended up having to wrestle with the manifold to get them replaced. That's just what I would recommend.
One more thing. If you're going to be replacing the PCV valve, replace the PCV valve hose with the new hose which is ribbed and stays open and doesn't crack and leak like the old one does.
Old Oct 28, 2012 | 06:25 PM
Chas944's Avatar
I second the updated PCV hose if you have not already. I had a sparkplug loosen up a couple thousand miles after a plug change and I used the factory spec w/ calibrated snap-on torque wrench. Dealer wanted to take motor out and machine head for plug hole threads. I Timeserted the hole and it is better than new. I recommend torquing the plugs to 19ft/lbs and using removable strength loctite as well just to ensure plugs stay in.
Old Oct 28, 2012 | 07:29 PM
Thank you-- I got the imt o rings and the updated hose with a new PVC valve and the upper and lower gaskets from jagbits so hopefully I can take care of everything in one shot.
Old Oct 28, 2012 | 07:31 PM
*pcv --damn auto spell on iPad
cissdm
May 3, 2016 06:02 AM
joesoap
Sep 10, 2015 01:09 AM
mrplow58
Sep 9, 2015 11:27 AM
MrMellor
Sep 7, 2015 10:22 AM
Bowman
Sep 3, 2015 03:17 PM
