Spark plugs???
Old Jun 22, 2012 | 11:43 AM
johnhdz21's Avatar
Default Spark plugs???
what brand would be good for spark plugs on my 02 Jag Xtype?
Old Jun 22, 2012 | 11:45 AM
Mikey's Avatar
You can spend all sorts of money trying this and that, but there's nothing wrong with the OEM plugs. Beware any plug that advertises better performance or mileage- it's BS.
Old Jun 22, 2012 | 01:31 PM
Thermo's Avatar
Veteran: Navy
johnhdz21, KISS (Keep It Simple Stu.....). All you need to get is a basic "Double Platinum plug". Do not worry about the multi-spark, or the umpteen prongs, etc. In modern day cars, the spark is large enough as it is that the need for these specialized plugs is not called for. You need the double platinum plugs because of these high energy coils that the car uses. You can stick in a conventional plug in, but you will be replacing it in 15K miles. After doing the plugs, you will understand why we will tell you to get the $4 double platinum plugs over the $1 conventional plugs.
Old Jun 22, 2012 | 02:03 PM
Fezz's Avatar
I just got my changed about a month ago, and felt a nice difference. I always stick to Iridium spark plugs - providing better performance and longer life span. It is a little more expensive than platinum, but like thermo said - avoid conventional plugs.
Old Jun 22, 2012 | 03:56 PM
PreJag's Avatar
I stuck a set of NGK Iridium IXs in mine last year and now have a miss under load, ie. pulling grades and passing. They'll be coming out and Denso plats (OEM) will be going back in. The problem with using different plugs is that the plug manufacturer's heat ranges aren't consistent from brand to brand. Too cold and you end up with performance problems.
Old Jun 23, 2012 | 03:39 AM
johnhdz21's Avatar
Thanx guys! Appreciate the info!
Justinb
E type ( XK-E )
Jun 21, 2023 05:29 PM
Poet
Oct 2, 2015 09:00 AM
42Ajd
Sep 26, 2015 07:04 PM
reb1999
Sep 26, 2015 08:41 AM
Boeingtravel95
Sep 14, 2015 05:01 PM
