Spinning bolt on front subframe help neded
Old Jan 3, 2016 | 06:50 AM
Lubino Do Rego's Avatar
Default Spinning bolt on front subframe help neded
Hi. Anyone have any ideas on how to deal with this. I was hoping to remove the rear bracket on the front sub frame. The two small 13mm bolts came of no problems but the large 21mm bolt is just spinning on ow side. I am thinking there is a captive nut on the other side that has broken free. Is the only way to get this by cutting through the floor panel?? Is this a square shaped tubing or a u shaped tubing? Any help appreciated.
Old Jan 3, 2016 | 06:54 AM
Paulc732's Avatar
Check out my thread.
you have 2 options both shown here.
https://www.jaguarforums.com/forum/x...e-free-113243/
Old Jan 5, 2016 | 10:10 AM
Larry-Cleveland's Avatar
As a general way of doing this is to losen everything else so that you have some weight on the bolt, or pry the part apart with a bar. Then use an impact gun on it. Sometimes you can also do this with just a ratchet, but I go for the guns!
Old Jan 5, 2016 | 11:31 AM
dwclapp's Avatar
Lubino: Paul's 'bent wrench' solution is the most elegant and least invasive approach. If that doesn't work for you, for whatever reason, cutting a hole in the floorboard is a 'Plan B'.
It's not as difficult as it sounds, and is described with pictures here: https://www.jaguarforums.com/forum/x...9/#post1216313
michaelodonnell123
Nov 29, 2025 02:39 PM
f_in_seattle
Sep 20, 2017 11:18 AM
stefos60
Jan 19, 2016 03:52 PM
Lubino Do Rego
Jan 3, 2016 02:27 AM
magmedia
Jan 2, 2016 08:41 AM
