split vacuum elbow pipe to turbo (diesel)HELP
Old Mar 23, 2010 | 05:56 AM
reggie's Avatar
Default split vacuum elbow pipe to turbo (diesel)HELP
Hi, I own a 2004 2.0Ltr diesel and just noticed the rubber connecting elbow is split which fits on what looks like a vacuum unit on top of the turbo unit. I went to my nearest main dealer and was told only the entire pipe assembly was available to order as a part at around £80, and its not even gold plated!!!
All I need is the little rubber elbow so I wondered if anyone has any suggestions as a I am not paying that.
Many thanks, Reggie
Old Mar 23, 2010 | 01:56 PM
BuckMR2's Avatar
With this forum being based in the US you probably wont get any help from virtually all on here as they never had the diesel engine X Type over there.
You have 2 possibly 3 choices....
Either the dealer or a breaker (like Eurojag in Darlington worlds biggest breaker usually have 400 Jags in at any one time)
Another option maybe a Ford one as a lot of the engine is the same as a Mk3 Mondeo...worth trying to find out as probably cheaper than Jag if same part.
Good luck
Old Mar 24, 2010 | 03:24 AM
reggie's Avatar
Thanks for that info, I will try the ford option first.
Regards, Reggie
richard bowles
Jun 10, 2023 12:24 AM
X308XJR
May 20, 2019 06:50 PM
Inspector
Oct 17, 2015 12:51 PM
xjrjag
Oct 12, 2015 03:16 PM
thedugger1
Sep 26, 2015 10:27 PM
