Steering wheel badge
Old Sep 1, 2012 | 12:07 AM
gragner66's Avatar
Default Steering wheel badge
Ok didnt want to jack the interior post so here is steering wheel post. Its just tad bit bigger than the factory badge. The outer ring Id say. It needs to be sanded down a little to fit flush or have stock badge removed. Any ideas on removal and not mess with airbag
stock
Old Sep 1, 2012 | 12:19 AM
Nardoswiss's Avatar
There is no way to change the badge on the airbag unless you want to try the airbag in action. Guys from the Russian Jag forum also had asked that question and some of them even tried to remove the badge. But resultless.
But on the other hand, if you'll do it successfully, you gonna be a true guru! )
Old Sep 1, 2012 | 12:41 AM
gragner66's Avatar
bummer so i guess using a flathead screw driver to pop it off is out of the question....lol are they bolted on the backside or something. or actually connected to airbag some how?
Old Sep 1, 2012 | 12:57 AM
Nardoswiss's Avatar
I guess it's glued. But I would not like to be the one who finds out. LOL.
+ The size of the badge and the way it's held on the airbag are might be important in an accident if the airbag deploys... we need a Jag specialist here!
Old Sep 1, 2012 | 04:49 AM
Cambo's Avatar
Here is a badge that was removed from the airbag of a 2003MY S-Type R
Obviously the airbag had been deployed.
Those tabs are pushed through slits in the leather and folded over.
So while you might be able to remove the badge from a complete airbag, you will never be able to put it back in the same way.
That might be ok if you are glueing the replacment badge on.
The other option is to buy an airbag from a later model, they had black badges instead of green...
Old Sep 1, 2012 | 05:02 AM
Aonsaithya's Avatar
As also seen on this thread;
So looking at that, there should be no risk of injury if you attach something else onto the original badge. As long as you attach it seriously well, that is. If it's lightweight and properly glued, then probably no issue.
Old Sep 1, 2012 | 05:50 AM
Cambo's Avatar
It's been done on XJ's and S-Types, but it depends a little on the actual badge that's on the wheel.
For example, that S-Type badge in my pictures above has a completely smooth face, the growler is not raised at all. You could easily just put a sticker over the top.
The badge in my X-Type looks the same, but the growler is raised, it's in 3D & you couldn't just put a sticker over the top. And it's not so easy to paint either, since there is green within the growler itself too...
Now the badge on my XJR, it's completely different. It's 3D but with no colour inside the growler, it wouldn't be too hard to paint over the green part. Which will be my next job I think...
And it has been done, here are some (unfortunately, very small) pictures...
Old Sep 1, 2012 | 12:19 PM
gragner66's Avatar
ok so here is what I came up with. i started with a center cap from Welsh Jag Parts. I ground it down till I could pop out center piece. Then smoothed the inner ring to where the badge itself just does pass through ring. All is smooth and looks factory. Here is the pics and final look. Not installed yet. Not sure best route to secure it. Dont want a poked out eye if I do need the airbag Any ideas?-hot glue, 2 part epoxy, super glue, or auto grade double sided tape?
Old Sep 1, 2012 | 12:26 PM
Cambo's Avatar
Double-sided tape gets my vote!
Old Sep 1, 2012 | 12:28 PM
gragner66's Avatar
Wow looks like jags in other countries got carbon fiber alot more that here in USA
Old Sep 1, 2012 | 12:30 PM
gragner66's Avatar
I like that idea myself. It is easier to remove back to original but it raises the whole thing for not as snug a fit
Old Sep 1, 2012 | 01:33 PM
Originally Posted by Cambo351
Here is a badge that was removed from the airbag of a 2003MY S-Type R.......................
Don't know about you but I'd prefer NOT to have something labelled C4 fired into my face in the event of an accident.
Where does this badge go when the airbag deploys?
Old Sep 1, 2012 | 01:50 PM
spielnicht's Avatar
Nice I didn't even notice that. I'd love to glue or tape a new one on top of the nasty one I've got now, but fear of it flying and lodging in my head or into one of my kids in the back seat keeps me hesitant.
Old Sep 1, 2012 | 02:30 PM
Cambo's Avatar
Did you see the pic from Aonsaithya above of the deployed airbag?
Old Sep 1, 2012 | 02:44 PM
A still pic doesn't give the full drama of deployment.
I believe they're still looking for the badge from this one!
Old Sep 1, 2012 | 03:06 PM
Cambo's Avatar
You don't need to sell it to me, I have a scar on my left forearm from a Holden Commodore drivers airbag....
Old Sep 1, 2012 | 04:06 PM
gragner66's Avatar
im pretty sure if you look up dumba$$ in websters dictionary his pic is there beside it. i wonder how many of those 40s they drank before they did it. on a more smarter note i may glue the badge on a piece of rubber and set it on a pack of M-80s and try it out. to see if it withstands the impact, wait how much have i drank today. yea i am concerned on the horrible event that bag ever going off
Old Sep 1, 2012 | 04:50 PM
Aonsaithya's Avatar
As long as the badge won't become unattached from the original badge, there shouldn't be any issues with it. It's not heavy enough to have any effect whatsoever on the airbag cover lifting up as the airbag explodes out of the steering wheel.
But yeah, they are like small bombs. Treat them with respect.
Old Sep 2, 2012 | 06:55 AM
Bigdiezel407's Avatar
As most have already stated, the airbag is considered, literally, as an explosive. I believe it deployes at a rate of 45 mph plus (approximately from what i can recall) so while it may break your nose or burn your arms or even lacerate you in some way, its simply ment to save your life in a worst case scenerio situation. The new badge does look good but insure you PROPERLY secure it down (an explosion sending something straight towards your face because it was only held on by double sided tape = not good).
Old Sep 2, 2012 | 09:19 AM
Originally Posted by Bigdiezel407
As most have already stated, the airbag is considered, literally, as an explosive. I believe it deployes at a rate of 45 mph plus (approximately from what i can recall).................
I don't mind the lunatics deciding they want this so-called safety device but I strongly object to being forced to have it fitted and working in my vehicles to pass the annual inspection.
In the event of an impact deploying the driver's airbag, I still want to see where I'm going and not have an opaque balloon obscuring the view.
If they must be there, make them transparent.
