Steering Wheel viberates at 62mph?
Old Apr 10, 2012 | 11:12 AM
fifasoccer's Avatar
Default Steering Wheel viberates at 62mph?
Hi Guys.
I am new here. Just baught a 03 x-type 2.5 with manaul trans, this past week. I Had put 400 miles with little to no issues except for steering wheel vibration between the speeds of 62- and 75mph. Any ideas what casues the wheel to vibe inbetween these speeds but not others?
Also, just yesterday, the clutch went out....I think? The clutch won't engage. Car starts, sounds great, but the car will not move into any gear regardless if the car is started or not. Could this be somethign other than just needing a new clutch?
any help or ideas would be really great.
Old Apr 10, 2012 | 11:28 AM
freebeeme's Avatar
For the vibrations is my guess that you simply let your wheels get balanced before other work is done.
The other question i cannot answer for you.
Old Apr 10, 2012 | 12:21 PM
Spooky pantz's Avatar
Mine did the same thing a couple years ago. It ended up being the tires. So i got new ones and now its so smooth enough to drive with one finger on the wheel
Old Apr 10, 2012 | 01:44 PM
Aonsaithya's Avatar
Welcome to the world of Jag!
I also noticed a vibrating steering wheel issue at roughly that speed, had the front wheels balanced and the issue went away.
The noise-paranoia is getting slightly out of hand (I have oversensitive hearing). At roughly 100-110kph, I hear a very weird, silent, resonance-like wailing sound that goes up and down like a slow siren. Nobody else seems to hear it.
Old Apr 10, 2012 | 02:56 PM
Mikey's Avatar
Vibration in 50-70 mph range is almost always tie balance or out of round problems. Try balancing to start.
For your possible clutch issues, does the shift stick move to it's normal position, or does it not move at all? Do the gears grind when you try while the engine is running?
Old Apr 10, 2012 | 03:55 PM
fifasoccer's Avatar
Hi Guys
I look into getting the tires balanced. I am quite sure the previous owner balanced them, before I baught the car. However i'll look into doing this.
As for the Clutch, the Stick moves into the different positions just fine. I don't notice any different noise, its just the gear does not engage.
Old Apr 10, 2012 | 04:20 PM
Mikey's Avatar
You might want to contact the seller of the car with this news and see what he's got to say.
Old Apr 10, 2012 | 04:25 PM
Bruce in North Dakota's Avatar
From: That Rectangular Hole in the Consciousness of America
When you get your tires balanced, MAKE SURE they use stick-on wheel weights!
Nothing ruins the looks of those nice Jag wheels more than some jackass pounding some lead weights onto those flawless rims.
Also, they will start corroding where the lead meets the alloy wheel.
Old Apr 11, 2012 | 07:56 AM
pab's Avatar
pab
The other possibility is that one or more of your wheels are bent. That happened to me and a wheel was actually cracked. Seems like the wheels that Jaguar used on these cars tend to be somewhat fragile and with low profile tires and pot holes... :-(
They should be able to tell you if the wheels are bent when they try to balance them.
Jaguar: Grace, Pace, and Space - Sir William Lyons
H20boy
Dec 24, 2024 03:23 PM
PMKimpton
Aug 3, 2019 08:22 PM
RobertTheBloke
Sep 24, 2015 11:48 AM
Burdedw
Sep 12, 2015 10:39 AM
1964Daimler
Sep 9, 2015 11:28 AM
