Strange.... 2 drain plugs on oil pan???
Old Mar 23, 2018 | 07:13 PM
Julianj08's Avatar
Default Strange.... 2 drain plugs on oil pan???
Bought an 05vxtype with transfer case already out... took out oil pan to replace gasket... saw only one drain plug which I unscrewed and the oil drained out... went to put back the oil pan and noticed another screw hole next to the one I took out... what hole is this? Why didn' t the oil come out if this hole before i unscrewed the first one? Help?
Old Mar 23, 2018 | 07:46 PM
Thermo's Avatar
Veteran: Navy
JUlian, from the sounds of things, you got a "mechanics special". Sounds like the one plug was siezed and the person drilled a new hole to put in a new drain plug. To the best of my knowledge, all X-Types only came with a single plug to drain the motor oil from.
Old Mar 23, 2018 | 08:36 PM
Julianj08's Avatar
Makes a lot of sense... thanks...
Old Mar 24, 2018 | 08:00 AM
Thermo's Avatar
Veteran: Navy
Juian, if you could, take a picture of the two drain plugs. I can tell by the picture what most likely happened. Granted, I bet if you put a wrench on the one that you didn't remove, it will be in there pretty good.
Old Mar 24, 2018 | 04:59 PM
astromorg's Avatar
That additional tapped hole is a blind one - it stops short of going right through. It's where the transfer box air cooling scoop is secured. It doesn't sound as though a previous owner bothered to replace it after an oil change!
Old Mar 25, 2018 | 01:51 AM
Dell Gailey's Avatar
@Astro, brilliant! Yup, that sounds right, mine is missing now after hitting an "iceberg" on the freeway.
M90power
Jan 21, 2015 04:33 PM
BStopek
Mar 3, 2013 11:30 AM
Jon89
Feb 22, 2011 05:33 AM
MRomanik
Oct 10, 2009 11:30 PM
RT
Jul 16, 2008 11:45 AM
