strange thumping noise from engine
Old Jul 3, 2024 | 02:18 PM
Marrakechhack's Avatar
Default strange thumping noise from engine
Hi
Im considering buying a 2.0 gasoline automatic here but when the engine starts up there is this really odd noise coming from the engine. It's not an engine knock, its more of a thump. Anyone have any ideas what it could be or where is a good place to start looking?
thanks
MJ in Marrakech
Old Jul 3, 2024 | 04:12 PM
h2o2steam's Avatar
If it is coming from the intake area, then check the air filter cartridge is seating properly and not able to bounce in the filter housing. Check the intake accordion pipe is properly secured with clamps and doesn't have an holes or tears in it.
The other intake issue that can occur (more when idling) is with the idle speed control valve that sits on top of the throttle body, it might be hunting if it is getting sticky and worn. Might need replacing.
Check belts for flat spots or damage and try to determine if the sound is synchronous with the accessory belt rotation.
But as always, try to isolate the area either with a mechanics stethoscope, a piece of tubing you can hold to your ear and then try to ascertain the direction of the sound, or a long shaft screwdriver that you can put the handle to your ear and touch the driver tip to various safely fixed locations to see if you can isolate an assembly source.
Good luck.
Manuel1234
Jan 4, 2024 06:27 PM
carzaddict
Nov 7, 2023 12:25 AM
RaffiNJ
XE ( X760 )
Jan 22, 2017 05:34 PM
vincent661983
Sep 29, 2014 05:46 AM
reyesl
Mar 19, 2014 09:13 AM
