Sunroof position
Old Jun 1, 2024 | 05:42 PM
dh53's Avatar
Default Sunroof position
I noticed that when fully closed the back of the sunroof is not flush with the sheet metal of the roof, it sits down a little over 1/4 inch. When in the fully tilted up position it also seems too low, the opening is slightly less than half an inch.
I went through the sunroof recalibration found here and the same as in the TSB found here. The sunroof moves as described it should but the position is unchanged after the calibration.
I had the sunroof removed not long ago when replacing the headliner. I didn't see anyway to make physical adjustments to the sunroof height or tilt angle when I had it all apart. It does not leak, I was in the car while someone sprayed around the sunroof with a hose and didn't see a drop. Maybe I am making up a problem where there is none?
Below are pictures of my sunroof in the fully closed position and in the "full tilt" position. Does this look right?
Fully Closed
Fully Tilted
pnacup
Apr 16, 2023 08:57 AM
cdma
Feb 10, 2023 02:11 AM
Grossy
E type ( XK-E )
Aug 26, 2021 01:02 AM
Versatile
May 27, 2014 08:26 PM
JoeIron
Nov 22, 2012 02:18 AM
