Suspension again
Old Sep 12, 2010 | 01:40 PM
Adam Lueb's Avatar
Smile Suspension again
I was going around a rotary (roundabout) yesterday at 35 or so mph. It has a terrible roadway I hit a bump and the rear end of the car seemed to jump to the right side a tad. Is this the control arms we have discussed in the pass, instead of getting off I went around again at the same speed and hit the same bump and it didn't jump. Am I being too paranoid?
Old Sep 12, 2010 | 06:18 PM
Thermo's Avatar
Veteran: Navy
Adam, try this, while making a wide turn at about 20 mph, play with the gas some and get on and off of the gas. Does the rear end feel like it wants to jump to the side? If so, the bushings on the lower forward trailing arm for the rear suspension are shot and you are feeling the slop in the suspension. The arms run about $100 per side and take about an hour each side to do. Just make sure to get an alignment afterwards so you don't trash a set of tires in the rear due to the wheels pointing in a new direction now.
Old Sep 13, 2010 | 02:27 PM
Adam Lueb's Avatar
Smile Suspension
I tried you advice today and the rear of the car was very stable. Perhaps it was just the way I went into the turn and hit the bump?
Old Sep 13, 2010 | 07:46 PM
Thermo's Avatar
Veteran: Navy
Adam, it may have been simply a ripple in the road that you hit and upset the suspension. Normally the first thing that you will notice when the suspension starts to go on your car is that the tires will tend to lean in on the top. So, keep an eye on this and when you can see the tires leaning in, you have worn parts. The front end can be adjusted some what, the rear unfortunately can not be (I am working on that though). The only way to restore this problem in the rear is new parts (upper control arm for the rear suspension).
Old Sep 14, 2010 | 04:21 PM
Adam Lueb's Avatar
I will keep an eye on the tires and thanks so much for your help.
tlynch
Dec 31, 2020 01:58 PM
Dutch xjrdiamond
Nov 30, 2019 09:14 PM
dmatthewman
Sep 30, 2015 10:10 AM
ChrisJay
Sep 27, 2015 09:08 AM
