suspension thud going over bumps
Old Oct 1, 2018 | 02:56 AM
eastwood's Avatar
Default suspension thud going over bumps
X-type jag. 2002 2.5 V6. only 14000 miles.. Loud thud from suspension when going over bumps at 40 mph plus
Old Oct 1, 2018 | 03:32 AM
Robman25's Avatar
Hi this is the wrong forum, you need the X type not XJ
Old Oct 1, 2018 | 03:48 AM
Steve M's Avatar
This is the X-Type forum?
Is it front or rear suspension?
Old Oct 1, 2018 | 03:55 AM
eastwood's Avatar
I think mostly front but possibly rear aswell.
Old Oct 1, 2018 | 04:01 AM
eastwood's Avatar
front mostly but possibly rear aswell.
Old Oct 1, 2018 | 05:13 PM
Dell Gailey's Avatar
https://www.jaguarforums.com/forum/x...g-tech-207025/
Need to narrow down front, back, left, right, under feet, by wheel, etc. to give helpful guidance. Shocks, loose components, dogbone, bushings, stabilizer bar(s), control rods, struts, strut bearing, etc. etc.
Old Oct 1, 2018 | 08:19 PM
Yorta2's Avatar
Not many miles on it, but (in my humble opinion) most common problem seems to be Front Stabiliser Link Rod(s). On the X-Type they are plastic rods, with normal steel bearings, but you can purchase steel link rods (which I put in on my car). Not an expensive item, available on eBay for around $30.00 each, and not hard to install. If this indeed turns out to be the problem, car doesn't need a wheel alignment after installation.
However, stabiliser bar bushes can also cause noise problems, and are a ******* to get out and in. I think your car is too low in miles to be them (yet). Get the car up on a hoist and check out the link rods for movement, as well as the stabiliser bar bushes. Good luck.
Old Oct 2, 2018 | 03:25 PM
Lol, loose spare tire in trunk, loose jack, ......
Old Oct 2, 2018 | 08:42 PM
iownme's Avatar
loose change
loose women
all leading to loose bowels and finally loose suspension
Dell Gailey
Feb 12, 2019 01:02 PM
wmlaven
Sep 4, 2018 06:18 PM
S-Typer
Aug 31, 2018 09:47 PM
The Mekon
Aug 4, 2018 02:30 AM
Time-Pilot
Jul 29, 2018 09:09 PM
