Synthetic oil?
Old Jul 17, 2013 | 09:19 AM
JaguarXKR's Avatar
Default Synthetic oil?
Hi,
I was wondering how many people run synthetic in their x-type's? I know the early X-type's say not to run full synthetic. I have a pretty late built x-type (07) and i cannot find anywhere in my manual that says not to use synthetic oil. Has anyone had any problems?
Old Jul 17, 2013 | 09:30 AM
MRomanik's Avatar
Veteran: Air Force
I've used Castrol synthetic in my 07 X Type since I got it in 09. No problems.
Old Jul 17, 2013 | 09:35 AM
Justink201's Avatar
I also use Castrol synthetic.
Old Jul 17, 2013 | 10:24 AM
oldpunk's Avatar
I just did my first oil change in my 04 since I got it. I used Castrol synthetic (I think it was called "Edge" or something), 5w30 and used a Mobil1 filter.
Everyone has their opinion, but oil is oil. As long as you change it at the recommended intervals, you should be fine.
Old Jul 17, 2013 | 10:51 AM
Mikey's Avatar
I think Jag removed the restriction from the manuals as they got tired of trying to tell people that there's no advantage- the engines couldn't care less.
Old Jul 17, 2013 | 03:09 PM
Thermo's Avatar
Veteran: Navy
I have used full synthetic, semi-synthetic blends, and straight dino oil. Atleast in my car, I have not noticed any difference in the motor or mileage.
Not to scare you, but some people have reported that because the synthetic oil molecules are smaller, they tend to find more holes to leak out of. But, if your engine is tight with no oil leaks, you should be golden.
Old Jul 17, 2013 | 07:33 PM
JaguarXKR's Avatar
My engine does not leak anywhere. But my transfer case leaks ever so slightly. I mean no drips or anything on any ground, that I have seen. But it sprays once in a while, since I can see it when it's up on the lift.
Old Jul 17, 2013 | 08:35 PM
Pfflyer's Avatar
I used to use Castrol Syntec religiously (got a hell of story about how good it was but that's for another time) but heard from a well-connected BMW specialist that they changed the formula a number of years of ago. I switched to Mobil 1 and use it in the Jags without reservation, every 5,000 with a filter.
Old Jul 17, 2013 | 08:39 PM
Mikey's Avatar
They've extensively changed the formula for Mobil 1 also. It's not the oil it once was.............
MrWhite
19
Jun 14, 2022 07:49 PM
caldoofy
Sep 28, 2015 08:43 PM
42Ajd
Sep 26, 2015 07:04 PM
Woznaldo
Sep 26, 2015 11:02 AM
ahunt4
Sep 25, 2015 03:43 AM
