Throttle position sensor probs
Old Dec 28, 2006 | 03:45 PM
BuckMR2's Avatar
Default RE: Throttle position sensor probs
If it were mine I would be checking the connector and if thats OK getting aused throttle body from a scrap yard.
Old Dec 29, 2006 | 05:10 AM
X2 Jag's Avatar
Im having the same issue with my 02 2.5. A Jag tech told me the same...that I need to replace the entire TB assembly. I stopped driving the jag because it kept going into Limp mode more often and leave me hi and dry when I need it the most. I had doubts that it was a TB issue but since you are mentioning the same incident now I believe it more.
Old Jan 24, 2007 | 04:36 AM
X2 Jag's Avatar
I know this thread is old but just wanted to post an update on this issue. I replace my TB with a brand new one about a week ago...it resolved the Limp Mode issue.
Old Jan 24, 2007 | 05:22 PM
X2 Jag's Avatar
HA...Id rather they be correct about replacing a part that will resolve my problem..luckily i didn't have to go to a dealer. I found this Jag tech on the outside, he checked my codes and when he told me to replace the TB I wasn't convinced by his expression...so I researched to make sure i was going to dump money on the right part. So im good...except now i have to change the yellow parking light on the drivers side since one of the clips broke off. [&o]
Old Jan 24, 2007 | 09:29 PM
Size:  4.6 KBhttp://cgi.ebay.co.uk/JAGUAR-X-TYPE-...em200069111741
Saw this on Ebay for £19.99
Jim C
Old Jan 29, 2007 | 08:53 PM
aquill1's Avatar
How much did the guy get outta you for the part?
Old Feb 2, 2007 | 03:31 AM
X2 Jag's Avatar
He got $650.[/align]
Old Apr 13, 2007 | 02:51 PM
bigdreams05's Avatar
Thanks for coming back and posting! Most people never come back to share their experience. It took you a while, but thanks a lot. You might save others a lot of money. What's the TB rebuild place's name and number so that others can get in touch with them in the event of the same problem?
Old Apr 14, 2007 | 12:38 AM
racerx82's Avatar
Rebuild the TB....yikes...that's like asking for trouble.....no?
Old Apr 15, 2007 | 04:23 AM
I wouldn't know, but I think it beats buying a new one for 1600 bucks!
Old Apr 15, 2007 | 05:01 PM
racerx82's Avatar
I suppose, but what do they rebuild on it?
Old Apr 16, 2007 | 12:59 PM
I'm guessing something with the throttle. I don't know about the X, but my S doesn't work with a cable like most other cars. Instead it's electronically responsive to the depth that my gas pedal is to the floor.
Old Apr 16, 2007 | 04:24 PM
racerx82's Avatar
Drive by wire...most new cars have the electronic version now....
Old Apr 17, 2007 | 12:04 PM
I meant to say most of the cars I've worked on. Either way, couldn't that part of the throttle body be rebuilt?
Old May 2, 2007 | 02:25 AM
altownsend's Avatar
jimmyfrank mentioned his solution and I have a question for him. I have the same problem with my car, 2002 2.5 X-Type Automatic.
Sometimes, the limp mode happens four or five times during a trip to a destination, even on the highway. I checked the wiring and cleaned the throttle body tonight. I will drive tomorrow and see if the lim mode kicks in.
I am sorry but I simply cannot believe that a throttle position sensor problem solution is replacing the entire throttle body. That is crazy. The engineers had to either do that on purpose to sell parts, or they were ignorant. I tell everyone that I come into contact with that this is happening.
Any way, is there a reason that the signal is lost that causes the limp mode? Let's look at that to see if there is a more reasonable/less expensive solution. Comments please.
Old Dec 4, 2013 | 05:15 PM
ivanonavi's Avatar
I have the same problem and I was told is my TPS but I haven't replaced it in almost 2 years. In order for me to prevent my car to go on limp mode I always drive with both my feet and yes the car is automatic, when i'm fully stop I keep the RPM between 750-1000 while stepping on the brake with my left foot and if i'm slowing down I step on the brake with my left foot while I keep stepping gently on the gas pedal at the same time. I know I shouldn't do that but it works and going to keep doing it until I fix the problem.
Hope this little trick help someone out there
Attached Thumbnails  Throttle position sensor probs-533390_10151427538777795_756082064_n.jpg
Old Mar 4, 2016 | 03:56 PM
rf69's Avatar
Default TPS sensor
Originally Posted by ;3050
My 2002 X-Type 3 liter has just gone over the manufacturerwarranty and I don't have extended warranty coverage. Last week the vehicle went into limp mode with an indication of a gear box fault. I had it diagnosed by a local dealer and he informed me that faul codes P0121 and P1573 were found and that the throttle position indicatorwas bad. He also informed me the PI was integral with the throttle body so the only remedy available from Jag was to replace the entire assemby. Part cost alone is $1665. I'm looking for a rebuild alternative. Any leads?
I've already tried toget consideration underthe warranty based on earlier complaints about shifting performance, but the dealer and Jag USA will not cover the repair.
Thx
Check EBay there are a lot of sales from salvage junk yards there that sometimes have used parts from Jaguars , for my 2004 XJ8 I got my used TPS sensor from eBay $39.99 plus shipping $6.00 and also got my Navigation DVD Player to replace the one from the trunk for a used one for $125 free shipping
