Tire wear ?
Old Jul 14, 2009 | 07:29 AM
TonyX's Avatar
Default Tire wear ?
Can you share your experience with front tire wear? What causes inside edge to wear? And what causes feathering on the outside edge?
Old Jul 14, 2009 | 10:28 AM
The Chris X's Avatar
Alignment issues. I've had the inside wear problem before, but not the outside feathering. Had the toe of both front wheels set to zero (or as close as possible) before my last new set of tires and have had very even wear since then.
Old Jul 14, 2009 | 06:20 PM
Thermo's Avatar
Veteran: Navy
Tony, like was mentioned, have an alignment done on your vehicle. The inside wear is caused by too much negative camber on the front tires. It can also be due to excessive toe. The toe is adjustable on our cars, but the camber can not. So, in order to fix camber issues, you need to replace either ball joints or upper/lower A-arms. IT all depends on which part(s) have worn out bushings. So, if you can figure out which parts are worn and need replacement before you take the car in for the alignment, that will be advantageous unless you can find a shop that is willing to look at the car, tell you the bad parts so you can get them replaced before getting the alignment done.
As for the feathering, do you like to take corners fairly fast? that can lead to feathering. It can also be a sign of an imbalanced tire. This will normally be felt in the steering wheel as a wobble.
If you need more help, let us know.
Old Jul 15, 2009 | 09:45 PM
TonyX's Avatar
How many miles did you put on since the alignment?
I noticed my front left inside tire edge was wearing a lot faster only after about 1.5 years or 15,000 miles since they were put on new.
Old Jul 16, 2009 | 06:28 AM
I'd have to take a look at my log book, since i switch between summer and winter wheels. Off the top of my head I will say about 20,000 miles between the summer and winter tires total since my last alignment. Of those, about 8,000 are on the new softer summer tires (Hankook Ventus V4). No inside edge wear.
Old Jul 16, 2009 | 01:20 PM
BuckMR2's Avatar
X Type has a wide tolerance range for alignment settings and many people including myself when I had my 2002 3.0 had problems especially with inside edge wear.Had the tracking set to straight ahead (zero) which is still within Jags tolerance and wear improved dramatically
Old Jul 22, 2009 | 12:00 PM
TonyX's Avatar
I had the front toe set to basically zero and smidgen(!) negative. I will monitor the wear pattern for next few weeks and go ahead and install new tires when I'm happy the new alignment will not wear out the new set. Thanks for all your input.
Old Nov 30, 2009 | 09:30 AM
afonda's Avatar
Default looking for an update...
I am having severe tire wear on inner edges of both front tires.
Last alignment was 4 months ago along with new tires all around. Fronts are going bologna skin on the inner edges. It looks like the front toe on both sides was set to -1/32.
The rear is further out than that but wearing normal.
I am guessing it must be the lower control arms and ball joints.
hoodun
May 25, 2020 09:08 AM
jagxk2008
Feb 4, 2016 09:53 AM
FabCat
Sep 26, 2015 12:16 PM
kiddhan625
Sep 25, 2015 12:04 PM
Don R
Sep 14, 2015 12:34 PM
