Transfer case!!!
Old Jan 22, 2014 | 11:14 AM
robiwhan's Avatar
Default Transfer case!!!
hi everyone, general question. i took my xtype 2.5 manual to the shop for new fluids. hey said they were unable to change transfer case fluid as it requires removing the unit itself. has anyone come across this or been able to have the work performed?
Old Jan 22, 2014 | 11:44 AM
Justink201's Avatar
Do a search for changing transfer case fluid. There is a full write-up on how you can do it yourself.
Old Jan 22, 2014 | 01:00 PM
Thermo's Avatar
Veteran: Navy
robiwan, in short, you have to refill the transfer case through the drain hole. Now, as how you go about this, you have 3 options that we have used:
1) tilt the driver's side up (about 24 inches as measured from the bottom of the door sill) so that you make enough room to put in the needed fluid, or,
2) one of the members had a kit that he had made that consisted of a check valve and a hose. From there, you connected up the hose and this overroad the checkvalve and let the fluid drain. Then you simply forced the fluid backwards through the hose to refill. Or,
3) you can get your hands on a radiator drain valve with a collar on the t-handle and then adapt it from the 1/4" NPT threads up to 1/2" NPT threads. From there, you open the valve to drain the fluid out and then you can run a piece of tygon down through the engine bay and put it into the collar of the valve. From there you can dump in the fluid you need and shut the valve once and equilibrium level is reached.
All 3 work. It is a matter of which method works for you.
Old Jan 22, 2014 | 02:06 PM
Bud Tender's Avatar
My method, works for me though YMMV.
Place catch pan under xfer case.
Remove plug on the side of the xfer case. Nothing will spill out.
Jack the passenger side ( US ) up so the door sill is 22 inches up.
Now the old fluid will drain out. If not you were really low on fluid.
Let that side back down
Switch to the drivers side ( US ) and jack it up 22 inches.
Fill through the drain hole until the fluid starts overflowing.
Put the plug back in.
Remove the catch pan
Let the vehicle back down.
Done.
This is just basic, You can use jack stands or cinder blocks as needed for your safety.
Old Jan 22, 2014 | 07:10 PM
GLH's Avatar
GLH
Default Transfer casw
Can the car be jacked the 20" off the ground with the tire jack or do I need a bigger jack.
Old Jan 22, 2014 | 11:15 PM
Bud Tender's Avatar
I have a big old floor jack and a couple 4x4 blocks that I use for my lifting needs.
I don't know high the included Jag jack will lift.
Old Jan 23, 2014 | 08:39 AM
pab's Avatar
pab
I wouldn't recommend it regardless of whether the jack can go that high.
You're going to have to get under the car and that jack seems kind of spindly to put much trust in.
Jaguar: Grace, Pace, and Space - Sir William Lyons
Old Jan 23, 2014 | 09:36 AM
Five Speed's Avatar
I think the difficulty lies in the fact , That at manufacture , they were supposed to be sealed for life .
Old Jan 23, 2014 | 08:19 PM
Bud Tender's Avatar
Life For a transfer case could be considered over when it burns up for lack of clean lubricant. So yes, it is sealed, for it's life. I want mine to last longer so I have brazenly broken the seal to drain out some old nasty lube and replaced it with the correct amount of clean new lube.
ArtyH
Oct 2, 2015 11:39 AM
millertic
Sep 30, 2015 08:11 PM
Johnken
Sep 30, 2015 02:46 PM
dmatthewman
Sep 30, 2015 10:10 AM
