Transfer case
Old Mar 20, 2014 | 07:58 AM
X2004's Avatar
Default Transfer case
Can anyone tell me how I can find out which type of transfer case is on my X-Type: viscous or non viscous?
P.S. I do not have DSC and the car is not a 2004.5
Thanks.
Old Mar 20, 2014 | 11:37 AM
Tony_H's Avatar
The way that actually tells you is to jack up the front and back on one side of the car. Put the car in gear and handbrake off. Turn one free wheel and the other will turn in opposite direction. If it turns freely then no viscous and if there is resistance then viscous. You probably don't have viscous in 2004.
Old Mar 20, 2014 | 02:22 PM
X2004's Avatar
Thanks for your help, but is there a simpler way to tell?
Old Mar 20, 2014 | 06:11 PM
Tony_H's Avatar
You can guess....
Old Mar 20, 2014 | 06:32 PM
Aonsaithya's Avatar
Send your VIN to Jaguar and ask? Assuming yours still has its original transfer case, that is.
Old Mar 20, 2014 | 06:44 PM
Thermo's Avatar
Veteran: Navy
X2004, if I remember right, the 02-03 (and early 04) transfer cases have a bulbous tail where the output shaft for the rear axle is vice having a much narrower tail shaft in the same spot for the 2004.25 and newer vehicles. It seems to me that there is also a difference in the spacing where the drain hole is between the earlier and later style transfer cases.
This picture is of an 03 transfer case. The 04+ as I recall have a bit more open hole there for you to work in.
Attached Thumbnails Transfer case-1-thermo-2759-albums-general-pics-32-picture-transfer-case-valve-upgrade-if-you-havent-done-your.jpg
ArtyH
Oct 2, 2015 11:39 AM
millertic
Sep 30, 2015 08:11 PM
Johnken
Sep 30, 2015 02:46 PM
dmatthewman
Sep 30, 2015 10:10 AM
