Transmission Fault/No Crank/Nothing
Old Apr 27, 2022 | 09:11 PM
NoCougarsAllowed's Avatar
Default Transmission Fault/No Crank/Nothing
Good Evening,
I'm new to these.posts therefore please be patient with me.
I recently just purchased a 2004 X-Type 3.0 AWD from a friend. The car sat for 3 years without moving but occasionally started to preserve the battery. The X-Type's reason for sitting is a slippage in the tranny which seems to be common for those cars. It has 150,000 miles and is in perfect shape inside and out. After purchasing I went to turn her over and it wanted to crank but due to low battey.voltage my.jump starter would not allow it to start. I took the battery out and charged it for 2 days on a slow trickle charge at 2 amps. I thought it would be enough to start the car. Before installing the charged battery I lifted up the battery box to discover the inlet and outlet stubs on the topside of the motor. With no way to check it warm I went ahead and put a half a.bottle of LUCAS brand transmission slip fix etc. I replaced the box and re-Installed the battery and now she won't do anything. I can hear a hum from the fue pump and that's it. All dash lights work and a message appeared in the odometer Info center saying transmission fault. I found the Inertia switch and pressed it (How do you know I engaged-disengaged it) but nothing. I released some transmission fluid from the 15/16ths drain plug on the tranny but nothing changed..
What have I done?
R
Old Apr 28, 2022 | 03:35 AM
Welcome to the forums,
I've removed your POLL. It's not appropriate for a first post or an effective way of getting advice on the issue.
Old Apr 29, 2022 | 09:15 AM
All Cattle No Hat's Avatar
It's doing exactly what mine did when I let the battery die in the car. A full charge and it started right up and the lights went out. The transmission warning is due to the low battery charge. Either make SURE that the battery is actually fully charged or get a new one. It should then start. Or at least turn over...
Old Apr 29, 2022 | 03:50 PM
Dell Gailey's Avatar
Or.... test the battery on this type of diagnostic tool (luckily the Walmart Superstore here has one = VERY expensive, like $15,000)., not the crap ones auto parts stores use. After 3 years the battery is most likely toast.
Old May 22, 2022 | 01:20 AM
JagQ's Avatar
if you read through the forum you will find many usefull posts that should help you diagnose the issue,
1st things 1st, check the battery , try jump starting see if it cranks, check battery cables and ground cables.
2nd, is your cigarette lighter adapter working ? if not check fuses, replace if needed, now is your climate control unit working ?
i do suggest doing a search using strings that will return the best results,
good luck.
TheOne
Jun 15, 2017 09:09 PM
Conrad Man
Mar 16, 2014 07:29 PM
badplan1
Nov 18, 2009 10:25 PM
denwhat
Oct 2, 2008 06:04 PM
