transmission problem code P0706
Old Jun 7, 2014 | 02:06 AM
dylonstomm's Avatar
Default transmission problem code P0706
ok i bought this jaguar has about 130k miles on it a few months in to having it when the car warms up it wont go in to drive or 4 but when the car is cold it works fine shifts fine if u put it up to 3 it goes in to limp mode but then works in all gears with reduced power but if u shift it fast enough from 3 back to drive it wont go in to limp mode and works fine thought it was the rotary switch replaced it did nothing still gives me the same code dont have a hole lot of money so not trying to just throw parts at it does any one have a idea what is wrong
Old Jun 7, 2014 | 02:09 PM
car5car's Avatar
Search and find out what this come mean. Post results.
Old Jun 7, 2014 | 07:58 PM
dylonstomm's Avatar
the code means transmission range sensor /circuit
Old Jun 7, 2014 | 10:02 PM
car5car's Avatar
It is probably easy to replace.
Old Jun 8, 2014 | 08:09 AM
DKurtti's Avatar
If you've replaced rotary switch already it may be the shift cable out of adjustment. Could also be switches in the J-gate. I would look at the cable first.
toronadomike
Jan 22, 2026 10:13 PM
philwarner
Oct 4, 2024 01:37 PM
laserguy
Sep 3, 2015 02:02 PM
SouthernGypsy
Sep 3, 2015 10:54 AM
OkieTim
Sep 2, 2015 12:48 PM
