Transmission question.
Old Oct 3, 2010 | 08:23 PM
Carwatcher's Avatar
Default Transmission question.
Hello all, I'm currently looking to buy an 03 X-Type but I have a quick question. On the test drive, I noticed the "S" button on the automatic transmission didn't work and I was just wondering if this is a sign of major transmission trouble or something minor?
Old Oct 3, 2010 | 09:10 PM
LEB's Avatar
LEB
Did you feel the car not shifting at higher rpms?
Or do you mean the light does not work?
Old Oct 3, 2010 | 09:24 PM
Carwatcher's Avatar
Well, I pressed it while driving and nothing happened. Light doesn't turn on either.
Old Oct 4, 2010 | 11:12 AM
sidewalkman's Avatar
S is sport, so your shifting points will be higher, if you're driving and press the button you won't notice a difference.
Standing start, use the same throttle pressure and look when it shifts. Do the same after you press the S and see if it is lower or higher (since if the light is burnt out you won't know whether you are in sport mode or not.)
If nothing changes likely the switch is pooched. But I don't think it has any effect on the transmission, it's electrical.
Old Oct 12, 2010 | 08:35 AM
chknhwk's Avatar
Actually, if you're driving and you press the button you CAN notice a difference, depending on certain circumstances. Dependent upon throttle application and rpm's, if you press the Sport button the car may downshift - mine does it all the time.
Old Oct 12, 2010 | 08:53 PM
Carwatcher's Avatar
Update - the battery died during the weekend and after charging it and starting the car, the button worked.
Old Oct 15, 2010 | 08:17 AM
chknhwk's Avatar
Ah, that explains a lot! LOL Stoopit electrical gremlins.
Poet
Feb 7, 2025 02:18 PM
kthrash
Feb 25, 2019 10:20 AM
CXJ
Aug 29, 2017 08:41 AM
Poet
Oct 2, 2015 09:00 AM
JTC3400
Sep 29, 2015 05:03 PM
