Troubles any help please
Old Nov 30, 2011 | 11:27 PM
dabears06082's Avatar
Default Troubles any help please
I have 2003 x type stopped for gas. returned to the car and got Nothing? no power at all,no start.If i left the key in the on position it would gradually power up enough for dash lights and interior lights. Jump would not start the car??? Few Clicks
3 meassages DCS fault Security Failure and Gearbox fault???
Had the car towed Any Suggestions
Old Nov 30, 2011 | 11:40 PM
disguay's Avatar
Because it is the 2003 and you can eventually get power I would rule out main fuses and say you should check your battery cables. The battery could be fine, but the x types tend to have really strange problems when the battery cable gets too old. The faults that you are getting is just because those systems don't have enough power to startup. I get those exact errors whenever my car dies and I try to start it. Replacing the battery cables should be pretty cheap and is a smart thing to do as preventative maintenance anyways so don't feel too bad if it's not your problem, but this really seems to point to the battery wire.
Old Dec 1, 2011 | 10:10 PM
mohrd's Avatar
Ditto. Check the underside of + cable that runs to bottom of the engine compartment fuse box first you may find the insulation worn through and making contact with a body bolt.
Old Dec 2, 2011 | 09:43 AM
queensnewbie's Avatar
This happened to me after I disconnected and reconnected my battery. I was getting secuirty and gearbox failure with all sorts of flashing dash lights. Sometimes power, sometimes no power. Just had to tighted the terminals and it was fine. I bet your connection may be loose or bad at the battery terminal.
magmedia
Aug 15, 2019 08:54 PM
LnrB
Oct 13, 2015 12:45 AM
speacock
Oct 3, 2015 11:15 AM
dpappyp
Sep 29, 2015 01:28 PM
