Turning problems
Old Jul 22, 2013 | 05:52 AM
Myjag2sexy's Avatar
Default Turning problems
If I turn my steering wheel either direction the car will stall out on me..also if I put the ac on. So I thought the ps steering pump was going so I replaced it and the problem is still there. Can it be the rack and pinion or something else running off the belts? My steering is a little stiff..any ideas?
Old Jul 22, 2013 | 08:22 AM
daxter1987's Avatar
Sound like a dirty throttle body to me. When you turn the wheel the steering pump put a higher load on the engine and since your throtle body might be sticking then it wants to stall. It also makes sense for the ac to want to make it stall.
Recomended fix:
Take out your air cleaner housing.
Check throttle body for black residue
Clean it with some throttle cleaner, available at your local parts stor, and a rag
Check your air filter now that you are there, replace it if its full of dirt
When you put it all back together I also recomend disconecting the battery over night to reset all the adaptions.
Hope that helps or gives you a place to start, Good Luck!!
Old Jul 22, 2013 | 08:33 AM
Myjag2sexy's Avatar
I hope thats all it is but doubt it..i will give it a shot after work with a update. Ty
Old Jul 31, 2013 | 07:27 AM
Myjag2sexy's Avatar
Didn't help..any ideas? I'm starting to thing its that pump on the subframe that the steering goes into..can this be replaced through the driver side wheel or must the sub frame be dropped?
Old Aug 8, 2013 | 03:24 PM
daxter1987's Avatar
I still wouldn't condemn the pump. Could also be a misfire of one of the coils failing. Even though you didn't mention a MIL can you check for codes?
JarodL
Mar 7, 2024 01:39 AM
mcdutch
Sep 4, 2015 03:38 AM
obwoodie
Sep 3, 2015 07:45 PM
laserguy
Sep 3, 2015 02:02 PM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
