Unlock car door without keys
Old May 12, 2017 | 03:01 PM
Dell Gailey's Avatar
Default Unlock car door without keys
Old May 12, 2017 | 03:37 PM
Thermo's Avatar
Veteran: Navy
Try it and let me know how it works for you. May I recommend using a basket ball as you will probably have better luck.
Using what they are saying in that the tennis ball is pressurizing the car door to push the lock mechanism up, you would have to apply around say 2 pounds of force to lift the lock mechanism (most take more than that, but I am going to give this the benefit of the doubt). Since the area of the lock is around 0.5 square inches, that means that you have to apply 4 psi of air to the interior of the door to push up with 2 pounds of force (4 psi x 0.5 in2 = 2 lbf). Making the assumption that the door is air tight (if you have looked at the inside of a door, you will see that this is completely wrong, but I am giving it the best chance that it has), the interior volume of a door is around 4 cubic feet (or roughly 7,000 cubic inches). So, you would need to raise the pressure inside the car door from 14.7 psia (normal atmospheric pressure, as measured in absolute pressure) up to a minimum of 18.7 psia. This would take something with a 1900 cubic inch volume (or roughly 12.5" x 12.5" x 12.5", or something bigger than a basketball). This is best case. Keep in mind that you are having to push this though that little key hole in a very short period of time to minimize air losses. in short, the pressure needed to do this is far more than what you can generate.
If you make the assumption that the air is somehow causing the tumbler to move and magically hit the right points to allow things to move, I could possibly give you that. But, this is where that falls flat. This is assuming that the air pressure is being applied unevenly and can somehow move all the internal parts of a door lock to the correct place and then at that same moment, cause the internals to twist in the correct direction to flip the lock mechanism. Good luck on lining up the stars on that one.
Just saying............
Old May 12, 2017 | 05:03 PM
hlgeorge's Avatar
Old May 12, 2017 | 06:40 PM
Thang Nguyen's Avatar
The doors are not air tight, plus the lock mechanism are connected with many rods and lock solenoid to push and pull, the air in the tennis ball can not push it up like that.
Old May 13, 2017 | 04:00 AM
DUNKS's Avatar
Hi Mr Thermo. Are you saying that you don't think it will work?
Old May 13, 2017 | 08:24 AM
Rchiv's Avatar
I do not think this will work on the X Type. Double locking requires a remote or key. When double locked you cannot open doors from inside.
Roger
Old May 13, 2017 | 08:47 AM
Thermo's Avatar
Veteran: Navy
DUNKS, *puff puff pass* Dude, sure it will. Just have to have a little bit of faith. LMAO.
Like the Mythbusters found out, it only works one way. I don't want to spoil the video.
Old May 13, 2017 | 02:02 PM
DUNKS's Avatar
Default LOCKS
Cruel man!!
Old May 13, 2017 | 04:12 PM
Thermo's Avatar
Veteran: Navy
DUNKS, granted, I have a much better way of opening the door. Unfortunately my way can only be done one time. Something about a pound of C4 wrapped neatly around the edge of the door. You can get away with only about 8 ounces, but then you have to use a shaped charge to get the needed effect. Gotta love working with the security guys. The things you learn that makes life much more interesting.
Old May 13, 2017 | 04:15 PM
Geez Louise, Thermo. Posted that for some giggles & you go all Mr. Wizard (yeah, I'm that old) on me. You HAVE to be an engineer, lmao!!
Old May 13, 2017 | 04:36 PM
DUNKS's Avatar
Default C4
Thermo. Reminds me of the .IS. Training officer demonstrating a suicide bomb.
"now watch carefully cos I'm only doing this once"
Better go now before this thread gets silly.
Old May 13, 2017 | 09:04 PM
Thermo's Avatar
Veteran: Navy
Dell, ironically, I am not an engineer. Just a "lowly tech" that has had to school some engineers in my day. My job requires me to know a bit about everything. Mix in some general curiosity about things and a willingness to learn, the world is a fruit basket waiting to be picked clean. What can I say, I love to learn about things and add it in with the other stuff I have learned to really find some interesting ways to do things. Toss in some general curiosity and oh lord can you have some fun.
DUNKS, you are talking to the guy that has climbed inside of a nuclear ballistic missile and also had to learn how they make nuclear bombs. The vests are too small of a boom for me. If I yell duck, don't be asking "where"? He he he he he he. Ever seen a water gun that uses 3000 psi air to shoot the water? I have. All you see is a little silver dot flying at you (right before it hits you and knocks you off your feet). Oh the days of being on the submarine.
Old May 14, 2017 | 04:12 AM
DUNKS's Avatar
Default SUBS
Hi Thermo.
I fear ye not! Spent my twelve years in the ROYAL NAVY on Battle class sub chasing destroyers. OH to see those depth charges fly. Not to mention the hedgehog!
HMS Hogue, Finisterre, and Myngs. Real ships!
Twas a while ago.
