Upgraded wiring harness for headlight, dipped beam and fog lights
Old Dec 11, 2014 | 09:43 PM
mikeb's Avatar
Default Upgraded wiring harness for headlight, dipped beam and fog lights
I bought my wife a completely stock 04 Entry Level Wagon with 30,000 miles. Headlights, dipped beams and fog lights are all factory original H1 incandescent 55 W bulbs for Hong Kong and China markets.
Last week I noticed a burned out headlight bulb. When I took off the housing cover, the power supply wiring insulation was crispy and flaking off the wire. Up to one inch of bare wire leading to each bulb. A testament to Thermo's constant message that the stock wiring is inadequate for 55W bulbs.
I need to replace the wiring, but feel no need to upgrade to HIDs. The top speed on Lantau Island is 70 KM, or about 43 MPH, so we don't need lighting for a longer distance in front of the car. The 55W incandescents are more than adequate for our speeds and road conditions.
I see a complete H1 upgraded wiring harness for up to 4 H1 bulbs on eBay. http://www.ebay.com/itm/H1-Ceramic-QUAD-OUTPUT-Relay-Wiring-Harness-Headlight-Foglight-Bulb-Booster-100w-/201016510816?pt=Motors_Car_Truck_Parts_Accessories &fits=Make%3AJaguar|Model%3AX-Type&hash=item2ecd848960&vxp=mtr
Has anyone used this harness, and what is your experience? They describe this harness as a more generic application for several different makes and models, so I am going to assume some adjustment for length of the wiring will be required. I don't care for a lot of extra wire coiled up and hanging around the engine bay.
Secondly, this product has wiring for 4 H1 lights, and I have 6 H1 lights. Does anyone know of a supplier for an upgraded harness for the third pair of H1s--the fog lights? Barratts, do you guys have anything like this? I prefer to buy something already available, but, if it is not currently on the market, I am sure I can find a good quality source in China to custom make what I need.
Thank you for any support you can give on this. Merry Christmas and Happy Holidays from Hong Kong.
Old Dec 12, 2014 | 02:46 PM
Thermo's Avatar
Veteran: Navy
Mike, save yourself a lot of time and money. What you need to worry about is simply pulling the old wiring out of the headlight housing from the headlight bulb back to where it attaches to the first terminal inside the headlight housing. Then you need to get your hands on some telfon insulation wiring (most of what you will find made these days). The teflon insulation is going to handle the bulb heat much better and not flake like you experienced. You can replace the 2 wires inside of each headlight.
You don't need the relay setup as your car is already using a relay setup. Not to mention that the relay setup is only going to replace the wiring between the fuse box and the headlight housing. This wiring is just fine. it is really the last few inches of wiring inside the headlight housing that is the point of concern. Hence the replacing of the wiring like I mentioned above.
If you need some other ideas, let me know and I will assist however I can.
Old Dec 12, 2014 | 06:59 PM
mikeb's Avatar
Thank you, Thermo. This forum is really valuable.
Old Dec 12, 2014 | 08:43 PM
motorcarman's Avatar
Jaguar issued a "Jaguar EPQR - View FAQ" in June of 2005 for this fault.
We got a KIT with wires and connectors to repair the headlamps.
Here is the FAQ with the PICS.
bob gauff
Attached Thumbnails Upgraded wiring harness for headlight, dipped beam and fog lights-xtypeheadlamp1.jpg   Upgraded wiring harness for headlight, dipped beam and fog lights-xtypeheadlamp2.jpg
File Type: pdf
Old Dec 19, 2014 | 09:39 PM
mikeb's Avatar
Bob and Thermo. I am getting nowhere with the Jaguar parts and service reps here in Hong Kong (Aberdeen and Kowloon). They finally say Jaguar has no part numbers 418-411-76 and 418-411-77. They can supply only the wiring harness from the fuse block to the headlamp. OK, possibly my car has a different wiring harness because it is made for the China market, but I doubt that. VIN SAJAG55S44YE13154. 2004 Estate Entry Wagon, 2.0L, auto. I am posting some photos for you to check it out. I am an electrical wiring novice at best, but the wiring on my car looks the same as the photos in the FAQ you sent, Bob. What next? Maybe I go to Jaguar US or UK to buy the parts, replace only the burned wires with something I find on eBay, have new harnesses fabricated by a shop? What are your suggestions?Upgraded wiring harness for headlight, dipped beam and fog lights-img_0404.jpg
Upgraded wiring harness for headlight, dipped beam and fog lights-img_0406.jpg
Upgraded wiring harness for headlight, dipped beam and fog lights-img_0408.jpg
Upgraded wiring harness for headlight, dipped beam and fog lights-img_0413.jpg
Old Dec 21, 2014 | 01:44 PM
Just go to a supply store and buy some 1/4" female spade connectors and replace the melted ones.
You can use butt connectors to add wire.
When we ran out of the components in the kit we just used common electrical parts.
bob gauff
afterburner1
Dec 16, 2015 12:12 AM
redrover41
23
Sep 25, 2015 01:33 PM
Dicque
Sep 19, 2015 12:53 PM
laserguy
Sep 3, 2015 02:02 PM
King Charles
Sep 3, 2015 12:40 AM
