Vacuum Hose
Old Oct 4, 2020 | 06:33 PM
Tim Ellis's Avatar
Default Vacuum Hose
I have a split in the vacuum hose that runs from front to back under the plastic cover on top of the engine of my 2002 X Type. (The cover with three screws that you have to take off the oil filler cap, to remove). The pipe is about 8 inches long and about 3/4 inch wide. I've fixed it temporarily with tape but want to order a new one. Can anyone advise part number or description. Also is it a special Jaguar part or will any hose of the right diameter be OK?
Old Oct 4, 2020 | 08:54 PM
motorcarman's Avatar
The crankcase breather hose from the PCV valve was superseded to a stronger version with reinforcing ribs (part number C2S40863)
There was a TSB but I can't find it right now.
Old Oct 4, 2020 | 10:25 PM
Tim Ellis's Avatar
Thanks for the info. Do you know if the hose comes with special connectors on the ends, or could any hose of the right diameter be used?
Old Oct 5, 2020 | 02:22 AM
Welcome to the forums Tim,
I've moved your question from General Tech Help to X-Type forum. This is the place to post technical questions about your model.
Old Oct 5, 2020 | 06:36 AM
Thermo's Avatar
Veteran: Navy
Tim, if you go to your local dealership, they should have them behind the counter. Common part to be replaced. You can try your local auto parts store, they will probably tell you that they don't have the part. If they say that, tell them you have the same year Lincoln LS with the 3.0L engine. That should get you the part you need.
FYI, you can find them on e-bay as this listing shows: https://www.ebay.com/itm/Jaguar-X-Ty...gAAOSw44BYGNsc
The part number is
C2S40863
Old Oct 5, 2020 | 12:47 PM
Tim Ellis's Avatar
OK, thanks a lot for the info.
Old Oct 5, 2020 | 12:48 PM
Tim Ellis's Avatar
That's great, thanks for the info.
Old Oct 8, 2020 | 09:47 AM
Backhertz's Avatar
Default Here’s another source of supply
https://www.rockauto.com/en/parts/ür...on)+hose,11784
Windell
May 14, 2017 06:56 AM
Luxurytax
Jul 7, 2016 07:18 PM
1964Daimler
Oct 11, 2015 10:43 AM
1951sms
Aug 1, 2015 01:43 PM
sidescrollin
Dec 6, 2012 02:53 PM
