What are best parts and fluids for the X-Type????
Old Jan 9, 2008 | 08:30 AM
EDLFWood's Avatar
Default What are best parts and fluids for the X-Type????
*****= best ****=great ***=good ++=you must do this upgrade or you are missing out.
*****[REGARDING OIL AND OIL FILTER]O.K. I will take a chance here and start things off. I found Royal Purple 5W-30 (about $7.00 each)to be the best so far, I was using Mobile 1, the Royal Purple seems to let the car start in cold conditions much better. The engine seems to run smoother too. K&N seems to make the best Oil filter too($12.00 each filter), the part number for the X-Type is Part Number: K33HP2009 and the manufacture number is MFR#: HP2009.
****[REGARDING ROTORS AND BRAKE PADS]Looks like EBC for Brakes too! EBC SPORT SLOTTED AND DIMPLED BRAKE DISC SET. For the front-Part Number: E35GD981, MFR#: GD981* about $170.00pairand for the rear-Part Number: E35GD1050, MFR#: GD1050*about $150.00 a pair. The EBC pads are EBC REDSTUFF CERAMIC 3000 SERIES BRAKE PAD SET, Front-Part Number: E35DP31322C, MFR#: DP31322C ($83.00)* Rear-Part Number: E35DP31350C, MFR#: DP31350C ($65.00)*
I also found these at Vivid Racing? Rotora Front Left and RightDrilled & Slotted Rotor Jaguar X-Type 02-06each!! $157.99 Part #R.20016.1C, andR.20016.2CandRotora Rear Left Drilled & Slotted Rotor Jaguar X-Type 02-06each $112.99Pat #R.20017.1Cand #R.20017.2C.
****[REGARDING AIR INTAKES] JaguarXP Jaguar X-Type Mark III performance intake kit. $179.99 Helps with torque and top end.
*****++[REGARDING MESH GRILL UPGRADE] JagaurXP Jaguar X-Type Mesh Grille Insert$99 or Jaguar X-Type Mesh Grille $295.00. I can say that this upgrade gives great performance gains (lets much more air in) and makes your X-Type look amazing.If you do one thing to your X-Type do this!JAGXP 1-866-310-5247
I am looking for input here and trying to build a consensus if you know about theseor any other products that work the best please comment and if you think I am wrong please say why. Like I said I amtrying to start a deffinative list of things that work the best with the X-Type.
*= Part number for X-Type only!!!
[align=center]SO FAR![/align][align=center]Best Oil: Royal Purple 5W-30[/align][align=center]Best Oil Filter: K&N Oil Filter[/align][align=center][/align]
[IMG]local://upfiles/2831/1FB8E708C3724944BD6CAAEB6D4192E8.jpg[/IMG]
Old Jan 9, 2008 | 07:42 PM
jasonzimbran's Avatar
Default RE: What are best parts and fluids for the X-Type????
As far as for brakes your right add the extra money and go for the slotted rotors.
Old Jan 10, 2008 | 02:08 AM
Size:  6.3 KBName:  X6JYMSAAB5.jpg
Size:  6.1 KBName:  AudiX6JYM-2.jpg
Spot on with the brakes EDLF
Jim
Old Jan 10, 2008 | 05:42 AM
Chas944's Avatar
EDLFWood, how do you like the JaguarXP intake for your X-type? Any gains in performance, throttle response, intake harmonics sound?
I was thinking of getting one for my new 2002 X-type Sport.
Appreciate the feedback!
~ Charles
Old Jan 27, 2014 | 09:10 AM
Stuart Beattie's Avatar
Hi Guys,
was the original post an advert as it has never been followed up?Obviously I like Charles above would have been keen to know more!
Old Jan 27, 2014 | 09:40 AM
Stuart,
You could be waiting a long time for a reply. The OP's last login to the forum Feb 5th 2008.
Sixth Anniversary next week.
Old Jan 27, 2014 | 11:26 AM
Ha ha, quite right Graham,
That's why I asked.. and ahem I wanted to know!
I Love this forum! Life just wouldnt be the same..............
way2far
Aug 31, 2022 09:26 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
sogood
Sep 15, 2015 07:35 AM
Whitnessmouse
Sep 4, 2015 11:09 AM
pnwrs2000
Sep 3, 2015 11:55 AM
