What is a full tune-up for X-type?
Old Jul 15, 2014 | 12:42 AM
jaguarisbeast619's Avatar
Post What is a full tune-up for X-type?
Hey! This Place is awesome! I just bought a used x-type and I want to give it a full tune-up, What does this include? A list is all I need. Thanks in advance!
Old Jul 15, 2014 | 08:37 AM
Thermo's Avatar
Veteran: Navy
Beast, you will find that there is no real "list" as everyone has different ideas of what a tune-up entails. Even professional shops do not agree as to what should be done. This is my idea of what should be done:
-Spark plug change out
-Air filter checked (replaced if necessary)
-clean MAF sensor
-Clean throttle body
-INspect/replace PCV valve
-inspection of hoses for cracks
-inspection of serpentine belt (replace if needed)
-Inspect rest of motor for anything leaking (coolant, oil, etc). Top up fluids as appropriate.
Some may also recommend changing out engine coolant. That is up to you. Some may say that this is also a good time to renew the tranny fluid and even the transfer case fluid.
Old Jul 15, 2014 | 09:34 AM
Diavolo's Avatar
Change oil
Change coolant
Change air filter
Change fuel filter
Every 60k change transmission fluid
Every 90k change spark plugs
Every 90k change differential fluid.
Replace hoses and belts as needed.
Inspect braking system.
Inspect lights.
Rotate tires.
Look up a maintenace schedule for a full list.
Davidvdm
Oct 7, 2015 03:18 PM
sawduster
Oct 3, 2015 12:10 PM
ssshield
Sep 24, 2015 08:29 PM
texaspete
Sep 10, 2015 08:34 AM
Whitnessmouse
Sep 4, 2015 11:09 AM
