what kind of plugs do you use
Old Jul 28, 2008 | 11:15 AM
loaks111's Avatar
Default what kind of plugs do you use
just wondering what kind of spark plugs were being used. i haven't done the ones in the jag yet but should get to thinkin about it
Old Aug 3, 2008 | 02:13 AM
Grim001's Avatar
Default RE: what kind of plugs do you use
Well your in for a shock. Changing the spark plugs on our cars is a pain in the butt. There are three plugs against the firewall that will require you removing the intake manifold and some other small stuff. Might want to start researching how to do it if you want to do it yourself. How many miles do you have on your x type?
Here is a link on how to do it and it also has the spark plug #s in the article.
http://jagmotorproject.blogspot.com/...ing-plugs.html
Old Aug 4, 2008 | 12:23 AM
loaks111's Avatar
worst thing i ever changed plugs on was an 81 vette had to pull 3 from under thecar took almost 2 hours
Old Aug 13, 2008 | 05:58 AM
Chas944's Avatar
I am about to do this here soon. I chose Champion Iridium 9204's: Champion iridium plugs have a superior .7mm fine-wire center electrode which results in maximum life and spark performance. And every Champion iridium spark plug features an iridiumcenter electrode with platinum tipped V-trimmedGround electrode and an exclusive Heat-Active alloy which maintains stable operating temperature under all engine loads.
They were less expensive than the Denos's and NGK laser cut Iridium's and offered the same specs such as fine-wire electrode and platinum ground electrodes. I got mine at Pep Boys for $6.99/plug.
Autolite Double Plat's are the superceded OE plug to date. But there is a large gamut of plugs available. I chose the Iridiums for thier long life and because they will last longer than 70k since this job is kind ofPIA.
Old Aug 13, 2008 | 05:59 AM
Chas944's Avatar
ORIGINAL: loaks111
Worst here was a 1976 Corvette! I am sure my Snap-On wrench is still laying on the cross member of that car!
aholbro1
Dec 29, 2024 06:46 PM
Rivguy
Nov 13, 2022 02:55 AM
JWheeler
Nov 22, 2019 08:28 AM
Boeingtravel95
Sep 14, 2015 05:01 PM
Mosers63
Sep 6, 2015 02:53 PM
