What is this part? Leaking?
Old Aug 16, 2015 | 03:45 PM
04Sport's Avatar
Default What is this part? Leaking?
Underneath my car on a lift and facing the front. To the right (on pass side) of the driveshaft near transfer case I keep finding some kind of fluid on the part pictured and am not sure what that is. Could it be coming from above and settling there or is this particular part leaking something? Thanks!
Old Aug 16, 2015 | 04:29 PM
Dr dome's Avatar
what color is it? what does it smell like? It could be oil from the engine or oil from the transfer case. two different smells all together.
Old Aug 16, 2015 | 06:18 PM
Justink201's Avatar
Yeah that part wouldn't leak oil, its a "roll restrictor" engine mount. Its just bushings in an aluminum housing.
Old Aug 16, 2015 | 07:07 PM
Dr dome's Avatar
It looks redish, My guess trany or t case
Old Aug 16, 2015 | 08:48 PM
DPK's Avatar
DPK
I can't see the color per se..But if it stinks real bad, it's TC lube. The TC has a vent on top and some lube maybe coming out.. if it's mild oily smell it could be transmission leaking or engine oil
Old Aug 19, 2015 | 11:15 AM
jag87's Avatar
I think its the seal in the back of the transfer case. When the driveshaft turns its spraying transfer case fluid all under the car This is the TSB for the fix. I have done it on mine, and it is fairly easy. I would get it done soon as there is not much oil is the transfer case when full and you do not want to run it dry or low on fluid.
http://www.jagrepair.com/images/TSB/...%20Leakage.pdf
You will need to refill the transfer case too, and there are a few threads on here that will help if needed.
Dicque
Sep 19, 2015 12:53 PM
sogood
Sep 15, 2015 07:35 AM
Xkr x100
Sep 6, 2015 08:50 AM
Dymaxxion
Sep 4, 2015 02:40 PM
OkieTim
Sep 2, 2015 12:48 PM
