Wheel Hub - Bearing. Circlip/ Retainer clip
Old May 22, 2020 | 07:19 PM
Alfredo Sanchez Lopez's Avatar
Default Wheel Hub - Bearing. Circlip/ Retainer clip
Hello people, I have an issue with my driver wheel, seems like the bearing of the wheel pushes the rotor into the breaking system again and again.
its my second rotor replacement so far and this guy told me that I’m maybe missing the retainer clip- circlip.
but I Already searched extensively on the web for a retainer clip for my car ( x type 2004 2.5) with no success
i know there are new wheel hubs with the bearing included, but I wonder if I just can buy the circlip and a new bearing to solve this issue.
txs for your time
Old May 22, 2020 | 07:49 PM
avern1's Avatar
The front vertical hub does not have a cir-clip. There is a cir-clip on the front axle and it is located on the end of the shaft in the gearbox. It can be purchased separately. Take a look at SNG Barratt's website and look at the front axle information. Not knowing what other work has been done I can't imagine that one missing but I suppose it is possible.
When the rotor damage is observed is the wheel bearing being pushed out of position. The vertical link only has a washer and nut holding the hub to the axle.
Old May 23, 2020 | 08:27 PM
Default This is the piece
Yes, it’s the wheel bearing circlip the piece missing...
It’s something like this one, but I can’t find the one for my model
: x type 2004 2.5
Old May 23, 2020 | 08:50 PM
avern1's Avatar
Attached is the picture breakdowns of the vertical hub and the axle. I still think the bearing is simply a pressed in fit and doesn't have a cir-clip. If it has one the parts book doesn't show it. You can try a direct call to SNG Barratt and maybe they can help you further.
Old May 23, 2020 | 10:11 PM
Default Just to be sure
First, I wanted to thank you for your time.
Missing that clip you showed me ( C2S47024) is what is making my wheel bearing to slip out and push my rotor enough to be eaten by the breaking system?
Old May 24, 2020 | 02:27 PM
avern1's Avatar
he axle should not be able to move back and forth, so I do believe that clip on the axle is your problem.
ian.fox
Apr 14, 2020 10:46 PM
wierciu
Sep 8, 2019 10:57 PM
2meke
Jul 2, 2013 03:36 PM
tenativelyproud
Mar 20, 2013 03:29 PM
