Wheel Removal 2002 X type
Old Feb 1, 2007 | 07:32 PM
vaccaro81's Avatar
Default Wheel Removal 2002 X type
Has anyone found an easy way to remove the alloy wheels from the X type? I have had to use a block of wood and a sledge hammer to wack away at alternate sides of the wheel with the lugs loosened until the thing finally breaks loose. There has got to be a better way to do this.
Old Feb 1, 2007 | 09:11 PM
Default RE: Wheel Removal 2002 X type
ORIGINAL: vaccaro81
Hmm Vaccaro, sounds like they aint been off the vehicle in a longg time mate.
Jim C
Old Feb 1, 2007 | 09:21 PM
vaccaro81's Avatar
Length of time is only part of the equation. The real problem is the chemical reaction between the alloy wheel and the steel wheel hub which causes a white powder to form inbetween the two surfaces. This powder hardens and does not allow the wheel to slide off, hence the whacking. I have tried spraying white grease on the surface of the hub prior to reinstallation but this didn't help at all. So the question still remains open.
Old Feb 1, 2007 | 09:45 PM
Only thing I can think of is to use (unsure of name) but its a sorta copper grease that they sometimes use when refitting bolts etc and I believe is also heat resistant.
Ask racer or Buck, those two knowalls will be sure to know.......lol and no doubt you'll have your answer before you can say f*c***g wheels ARGHHHHHHHH
Jim C
Old Feb 3, 2007 | 12:16 PM
badmojo's Avatar
Hi,
That copper grease is called anti sieze compound! It's also a good idea to apply it to the studs before replacing the lug nuts.
stanjag
Dec 29, 2024 08:26 PM
h4wk
Nov 27, 2015 05:10 PM
montypeek
Sep 6, 2015 04:57 PM
roumor
Aug 28, 2015 01:02 PM
brent65622
Aug 26, 2015 08:41 AM
