Wheel spacer sanity check and spec.
Old Apr 5, 2021 | 06:55 PM
Jag4's Avatar
Default Wheel spacer sanity check and spec.
Hello forum,
My understanding is a 5mm spacer shouldn't be an issue. Agreed, Thermo, others?
I believe this is the correct size?
https://www.amazon.com/dp/B07DX9R637/ref=cm_sw_r_cp_apa_glc_fabc_E1F6DHZVTSQBEQF6B5RH?_ encoding=UTF8&psc=1
Is there another brand I should look at?
Thoughts, gentlemen?
Thank you!!!
Chris
Old Apr 5, 2021 | 08:00 PM
Thermo's Avatar
Veteran: Navy
Jag4, yes, a 5mm spacer should be just fine. I would not go much more than that on the stock studs and lugs. You start affecting the strength of the studs due to limited thread engagement.
I guess I have a question to ask back: Why do you feel that you need spacers? Trying to understand what you are attempting to do to see if there is maybe another way to get what you want without stressing anything. Keep in mind that ultimately, you want to keep the center of the rim in line with the center of the bearing (front to back on the car and vertically). You get too much of a difference between the center of the bearing and the center of the rim leads to excessive forces and a shortened bearing life.
Old Apr 5, 2021 | 10:30 PM
Jag4's Avatar
I guess I have a question to ask back: Why do you feel that you need spacers? Trying to understand what you are attempting to do to see if there is maybe another way... <snip>
Hey Thermo, The reason is purely esthetics - widen the stance a bit. Thats all. Mechanically I can clearly understand what you're saying and agree. I would change the rims and tires if I didn't really like the stock chrome rims, which I haven't seen on any other X. Now running 225.
I open to alternatives.
Old Apr 6, 2021 | 06:29 AM
Thermo's Avatar
Veteran: Navy
Jag4, why not simply step up to 235's when you get your next set of tires. This will push the tires out the 5mm that you are after and improve traction for better cornering. THis also keeps the alignment of the wheel and bearing. Now, I will admit that the 235's are literally as big as you can go. You may even notice a slight amount of rubbing on the inner liner of the fenderwell. But, that is very minimal. Sure, the rim is not pushed out the 5mm, but most people would not notice that. What they are going to see is the rubber at the metal of the car. just a point to ponder.
Old Apr 6, 2021 | 01:42 PM
Jag4's Avatar
Jag4, why not simply step up to 235's when you get your next set of tires. <snip>.
I'd love to go to 235s but the only thing I can find is (tirerack.com/others) Pilot Sports $$$ 235/16/45s or other track-like tires. I don't need anything like this. Is there someplace else I should be looking for these tires?
Eventually I might decide to replace the rims. I have so much money into this vehicle already - very happy with it for now - whats another 1K!
Alright - thanks Thermo!
Old Apr 6, 2021 | 02:45 PM
Thermo's Avatar
Veteran: Navy
Jag4, I did some looking and you are finding more than I can find at the moment. Because you are running a 16" rim, you can probably step up to a 235/50R16 and be just fine. I was running 235/45R17's on my X-TYpe. So, you stay at the R17 diameter or smaller, then you should be good.
JeremyHand
Feb 6, 2018 08:37 PM
GMaxima
Jul 8, 2016 02:43 PM
ramandanu
Jun 27, 2015 01:32 AM
04xtype04
Mar 17, 2014 06:50 PM
Jaggyx
Mar 23, 2010 02:00 AM
