Window switch help please
Old Jun 22, 2023 | 09:14 AM
NYCJAG2006's Avatar
Default Window switch help please
What’s up guys. My drivers main window switch is acting up. Only the drivers window switch. Feels like it’s loose or disconnected possibly. Window still goes up and down. However I don’t want the window to get stuck in the open position. Is there any fix for just one switch in the main window control switch on the drivers door ? Or do I need an entire new switch ? Thx.
Old Jun 22, 2023 | 11:15 AM
Thermo's Avatar
Veteran: Navy
NYC, I would llook on e-bay and see if you can pick up the switch complex. You should be able to pick up a switch complex for fairly cheap. May want to even look at say a Ford Fusion and/or a LIncoln LS and see if the switch complex is the same between the models.
Old Jun 23, 2023 | 10:43 PM
Peter_of_Australia's Avatar
If it were my switch/problem, I would look for the root cause...
Loose connector? (not very likely)
Corroded connector pins? (likely)
Corroded contact surfaces inside of the switch? (likely)
Old Jun 25, 2023 | 09:22 AM
NYCJAG2006's Avatar
Seems to be just the drivers window switch itself. It’s been feeling weird the last week. When I go to raise the window it seems like the switch is loose and might pull out.
Old Jun 25, 2023 | 06:10 PM
Ah, you mean the actual "lever" dedicated for the driver's window in that switch, which contains 4 window levers!? That would probably mean that a little "nibble", which holds the lever in place, has broken off. Well there might be a way to fix that, but I am not sure how long a fix of broken plastic would last, plus, you have to be very careful not to loose any part when opening that switch. You would most probably be able to create one working switch if you have 2 broken switches (as all you need is a new lever for the donor switch). But as you are unlikely to find such a donor switch, your best bet is indeed to buy a new switch. 1X43-14A132-BE E-Bay Australia shows one for AUD$80. But this would be for the RHD version for the X-Type and I am not sure, if it is identical to the LHD, which you have.
Old Jun 25, 2023 | 09:08 PM
h2o2steam's Avatar
Same window switch packs for LHD as for RHD.
However (there is always a but !), there are four variants depending on whether you have electric windows front and rear (apparently there were models with manual rear window winders), and/or whether you have the power park mirrors feature.
Old Jun 25, 2023 | 09:21 PM
Yes, I remember now (as I think this window switch was one of the ones, which were in my electric-design responsibility): The reason as to why it is the same for LHD and RHD is, that that, what makes it different (the outer bezel), is an integrated part of the door trim.
And I think internally it might be the same as the Mondeo switch, but externally the Jaguar Stylists gave it a new appearance.
This is the Mondeo window switch (just as comparison):
https://i.ebayimg.com/images/g/hRIAA...1vo/s-l500.jpg
Old Jun 26, 2023 | 07:57 AM
NYCJAG2006's Avatar
Ok. My X has both front and back power windows with the one press or pull to raise or lower the windows with one hit of the switch. How do I know if I have power park mirrors please ?? Thx guys.
Old Jun 26, 2023 | 03:45 PM
h2o2steam's Avatar
Do you have a single small press switch above the large circular mirror adjustment switch?
That single switch is your side mirror fold button.
Old Jun 26, 2023 | 07:40 PM
When that topic of folding mirrors came up here, I did a little research. While I was relatively sure that I do not have folding mirrors, I wanted to know for sure (just in case I have them and there is a trick to activate them, which I don't know yet). I think folding mirrors are relatively rare on X-Type. But if you have them, it looks like they should fold, if you double-lock your car (i.e. press the lock button on the remote twice). That is one way the test and the other more obvious way to look at your switch (see Mark's picture above).
Old Jun 27, 2023 | 01:43 AM
NYCJAG2006's Avatar
Non folding mirrors. I can fold them manually
Old Jul 19, 2023 | 07:34 AM
yovenim's Avatar
Banned
Originally Posted by Peter_of_Australia
Ah, you mean the actual "lever" dedicated for the driver's window in that switch, which contains 4 window levers!? That would probably mean that a little "nibble", which holds the lever in place, has broken off. Well there might be a way to fix that, but I am not sure how long a fix of broken plastic would last, plus, you have to be very careful not to loose any part when opening that switch. You would most probably be able to create one working switch if you have 2 broken switches (as all you need is a new lever for the donor switch). But as you are unlikely to find such a donor switch decorative concrete Utah, your best bet is indeed to buy a new switch. 1X43-14A132-BE E-Bay Australia shows one for AUD$80. But this would be for the RHD version for the X-Type and I am not sure, if it is identical to the LHD, which you have.
Hi there, My GS300 Driver side window seems have problem, press on the window switch sometimes the window didn't work. So I pick up a second hand power switch and want to replace it, but how can I take it off from the door panel? Thanks.
Old Jul 19, 2023 | 07:50 AM
I never had a Lexus - and a GS300 is a Lexus. But when I googled what your window-switch looks like...: Very similar.
Thus: Remove the door panel and when removed turn it upside down, look for the inside and there should be roughly 3 little bolts under the window switch screwing the switch-unit to the door panel....
Obviously, before actually switching (=changing) the switches, you could try first to remove the connector from the OE switch, plug it into your new switch and see if it works.
TonyX
Sep 23, 2022 02:18 PM
macs99
Apr 16, 2017 01:06 PM
dickc
Jul 23, 2014 02:16 AM
Jsedita74
22
Jun 14, 2011 07:09 PM
johnpiero
Jan 24, 2010 11:38 PM
