x-type 2.1 v6 - engine stops
Old Oct 6, 2016 | 08:24 PM
George21's Avatar
Default x-type 2.1 v6 - engine stops
Hello guys and am sorry for my english.
I started my car today to warm up the engine and it has stop like run out of petrol and it doesnt start again..
when i turn on the switches at the las level i cannot hear the fuel pump/injection noise what that could be??
thank you in advance
Old Oct 7, 2016 | 06:16 AM
swingwing's Avatar
Your condition is called Crank No Start, and you have to find out whether it's caused by no fuel or no spark. From your post I'd say fuel supply is first thing to look at. You'll need to check fuel pressure at the engine fuel rail. There's a Schrader valve on the rail that a pressure gauge can be connected to. You'll also need to check the fuel pump relay. Lack of fuel supply could be simply a clogged fuel filter that's an easy fix. If your fuel pump has failed then you'll need to drop the tank.
Old Oct 7, 2016 | 09:34 AM
Bruce in North Dakota's Avatar
From: That Rectangular Hole in the Consciousness of America
Try resetting (pushing the button) the fuel cut-off switch, located in the passenger side of the front seat, down in the foot-well area on the upper side.
Something might have caused it to trip, like slamming the bonnet or a door shut, or just cat attitude.
Might be the easiest fix ever on a Jag - FREE!
Further instructions in the Owners Manual, or search the forum for more info!
Preacher-Steve
Oct 8, 2016 10:43 AM
SteveSheldon
Sep 20, 2016 03:17 AM
Eileen Jaggy
Sep 18, 2016 10:10 AM
Tomica
Sep 3, 2016 07:12 AM
xtypejag502
Aug 27, 2016 09:18 AM
