X-Type 2.5 awd gearbox removal
Old Apr 15, 2017 | 03:22 PM
Dooley's Avatar
Default X-Type 2.5 awd gearbox removal
Hi just brought my 1st x type
2.5 awd manual
Question is can i slide the box out and change clutch or do i have to remove the gearbox and how hard is this, does transfer box have to be removed?
Old Apr 15, 2017 | 05:09 PM
Welcome to the forum Dooley,
I've moved your question from Jaguar Forums Feedback & Suggestion Centre to X-Type forum. Members here with the same model will be able to help.
Old Apr 15, 2017 | 09:18 PM
motorcarman's Avatar
When I went to Jaguar Training New Product 2002 (NP02) we were told to remove the engine/gearbox as a unit with the subframe and separate on the floor.
I never did it that way and just did the gearbox removal like any front wheel drive (tilt gearbox down, pull back and out).
In September of 2003 Jaguar issued a REVISED procedure for gearbox R&R. Turns out they advised to do it the way most people did it ANYWAY.
See TSB/Service Action XT307-S941.
Start at page 10 of the Bulletin.
bob
Old Mar 31, 2019 | 12:27 PM
ThomasX's Avatar
Hi
Looks like I will be doing this job in order to replace a leaking rear crank seal.
I also have a 2.5 manual, 2002.
It is mentioned in the TSB that it concerns automatic gearbox, but I assume the procedure is the same for manual gearbox then?
David12345
Oct 6, 2016 12:18 PM
phreadd
Oct 6, 2016 10:10 AM
Nov 20, 2006 11:00 PM
Oct 11, 2006 07:18 PM
Humy
Jan 27, 2006 04:10 PM
