X type 2004 Auto. Transmission. reverse switch location
Old Aug 24, 2019 | 07:15 AM
JagQ's Avatar
Default X type 2004 Auto. Transmission. reverse switch location
Hello All.
could anyone pint out the location of the reverse switch on auto. transmission, i did search the forum but i could only find the manual tranny
Thank you
Old Aug 24, 2019 | 07:32 AM
Thermo's Avatar
Veteran: Navy
JagQ, the switch is on the side of the tranny. You should see a black plastic piece with a bunch of wires going to it. It should be bolted to the side of the tranny.
Old Aug 24, 2019 | 08:44 AM
JagQ's Avatar
Thank you for the reply, i have seen this many times and wondered what it was.
I should be checking for the fuse first, and in searching for the fuse i found your post :
Engine compartment fuses
Fuse Type Rating (amps) Colour Circuit
F1 Cartridge 20 Blue Dip beam, High Intensity Discharge (HID) light relay.
F2 Cartridge 50 Red Ignition relay feed.
F3 Cartridge 60 Yellow ABS.
F4 Cartridge 30 Pink Rear window heater/heated mirrors relay.
F5 Cartridge 30 Pink Automatic transmission control module relay.
F6 Cartridge 30 Pink Heater blower relay.
F7 Cartridge 50 Red Power supply to passenger compartment fuse box.
F8 Cartridge 80 Black Blower module.
F9 Cartridge 50 Red Engine management system power relay.
F10 Cartridge 20 Blue Headlight power wash pump relay.
F11 Mini Not used.
F12 Mini Not used.
F13 Mini 30 Green Heated front screen right-hand side.
F14 Mini Not used.
F15 Mini 30 Green Heated front screen left-hand side.
F16 Mini 20 Yellow Left-hand dip beam, day time running lights, autolights.
F17 Mini 20 Yellow Right-hand dip beam, HID lights.
F18 Mini 20 Yellow Throttle motor supply.
F19 Mini 15 Blue Screenwash pump, rain sensing system.
F20 Mini 5 Tan Navigation display.
F21 Mini 15 Blue Side (Parking) lights.
F22 Mini 20 Yellow Accessories relay.
F23 Mini 10 Red Air conditioning compressor clutch.
F24 Mini 15 Blue Door lock power.
F25 Mini 15 Blue Direction indicators (GEM).
F26 Mini 15 Blue Horns.
F27 Mini 10 Red Automatic transmission control module, transit relay.
F28 Mini 15 Blue Ignition switch.
F29 Mini 30 Green Starter motor solenoid.
F30 Mini 30 Green Accessory sockets.
F31 Mini 10 Red Engine management relay coil.
F32 Mini 5 Tan Engine management control.
F33 Not used.
F34 Diode D3 Not used.
F35 Diode D2 Engine management control relay diode.
F36 Mini 10 Red Canister purge valve, airflow meter, throttle motor relay, power wash relay,
air conditioning relay.
F37 Mini 15 Blue Engine management system, blower speed controller, road speed sensor (if fitted).
F38 Mini 30 Green Oxygen sensor heaters A.
F39 Mini 5 Tan Variable intake valves.
F40 Mini 15 Blue Automatic transmission control module.
F41 Mini 10 Red Injectors.
F42 Mini 30 Green Oxygen sensor heaters B.
Engine compartment relays
Relay No Type Rating (amps) Colour Circuit
R1 ISO 40 A 40A Black Windscreen wipers.
R2 ISO 70 A 70A Grey Heated front windscreen (optional).
R3 Micro 20 A 20A Black Horn.
R4 Micro 20 A 20A Black Accessories (optional).
R5 Micro 20 A 20A Black Headlight powerwash (optional).
R6 Micro 20 A 20A Black Air conditioning compressor clutch.
R7 ISO 70 A 70A Grey Engine management system.
R8 Micro 20 A 20A Black Automatic transmission control module.
R9 ISO 40 A 40A Black Dip beam/HID.
R10 ISO 40 A 40A Black Starter motor.
R11 Micro 20 A 20A Black Throttle motor.
Passenger compartment fuses
F60 Mini 20 Yellow Power windows left-hand.
F61 Mini 20 Yellow Power windows right-hand.
F62 Mini 7.5 Brown Rear fog lights.
F63 Mini 7.5 Brown Right-hand – front side light, side markers, rear tail lights.
F64 Mini 7.5 Brown Left-hand – front side light, side markers, rear tail lights.
F65 Mini Not used.
F66 Mini 30 Green Left-hand power seat switches, heater module, lumbar pump.
F67 Mini 5 Tan Battery back-up sounder, transit relay, HID/dip relay, automatic transmission control
module.
F68 Mini 15 Blue Cigar lighter.
F69 Mini 7.5 Brown Telematics display, In-car entertainment head unit, antenna module, navigation module,
VICS (Japan), parking aid, amplifier premium 1 system, phone handset, phone power
supply module, instrument cluster, PATS module.
F70 Mini 30 Green Right-hand power seat switches, heater module, lumbar pump.
F71 Mini 15 Blue VICS (Japan), telephone transceiver, telephone handset.
F72 Mini 15 Blue Radio head unit, CD player, navigation electronic control module,
Jaguar diagnostic connector/OBDII connector.
F73 Mini 15 Blue Sunroof unit/module.
F74 Mini 15 Blue Instrument cluster, Premium ICE amplifier unit.
F75 Mini 7.5 Brown Mirror fold back module, battery back-up sounder, air conditioning ECU.
F76 Mini Not used.
F77 Mini 7.5 Brown Left-hand and right-hand heated seats modules.
F78 Mini 5 Tan Phone power supply.
F79 Mini 10 Red Automatic transmission only: Reverse lights, reverse light switch, reverse park aid,
electrochromic mirror, instrument cluster.
F80 Mini 7.5 Brown Park interlock, heater switch, OBDII, blower relay.
F81 Mini 20 Yellow Fuel pump control module.
F82 Mini 10 Red Variable power steering, alternator.
Manual transmission only: Reverse lights, reverse light switch reverse park aid,
F83 Mini 15 Blue Not used.
F84 Mini 5 Tan Instrument cluster, passenger airbag fascia light, seat weight sensor.
F85 Mini 7.5 Brown Right-hand high beam light.
F86 Mini 7.5 Brown Left-hand high beam light.
F87 Mini 15 Blue Front fog lights, master light switch.
F88 Mini Not used.
F89 Mini Not used.
F90 Mini 7.5 Brown Stop lights, cruise control.
F91 Mini 10 Red Sunroof, electrochromic mirror, power windows, power mirrors.
F92 Mini 10 Red Manual transmission cruise control clutch switch, ignition coils, automatic transmission
rotary switch.
F93 Mini 30 Green Windscreen wipers.
F94 Mini 20 Yellow HID module.
F95 Mini 10 Red Airbag restraints module.
F96 Mini 7.5 Brown ABS module.
F97 Mini 7.5 Brown Glove compartment light, instrument cluster lights, licence plate lights.
F98 Mini 10 Red Mirror heaters.
F99 Mini 10 Red Luggage compartment light, footwell lights, puddle lights, vanity mirror lights, interior lights, aircon control unit, roof console unit.
Now, all of these are for a 2003 model car, but they should be close enough to give you the info that you are after. If you have any questions, let me know. If you want the computer files for the 2003 manuals, let me know. I have all of them.
however, these is no F79 , the numbering starts at F1
Jaguar X-Type Fuse Box Diagram » Fuse Diagram
any ideas ?
Old Aug 24, 2019 | 08:51 AM
JagQ's Avatar
Ok, found it in the diagram, that would be F2 & F34 and R9
will check.
Thank you
Old Aug 24, 2019 | 08:53 AM
astromorg's Avatar
Mmm! Not on mine!
In the auto models (not the manuals) The reversing lights are fed from a relay, R9 (R17 in earlier models) in the Glove box fuse panel. The power for that comes from Fuse F2, 10A (F79, 10A in earlier models) in the glove box fuse panel. The relay R9 itself is not serviceable, being built in to the fuse panel, but the earlier R17 is a standard relay!) (Go figure!)
The signal to the relay to put the lights on comes from the transmission module to the instrument panel via the CAN bus system. That then grounds the relay circuit to operate the relay.
So in practice, depending on an early or late model, there's the bulbs, the fuse, the relay (maybe!) and the wiring to check
Old Aug 24, 2019 | 08:57 AM
JagQ's Avatar
Originally Posted by astromorg
Mmm! Not on mine!
Yes that is true.
It was Fuse F2, replaced it and it all worked.
Thank you for your reply. And To Thermo for his.
Mar 17, 2018 11:12 AM
Chas944
Jul 29, 2017 05:11 PM
jwf73056
Sep 23, 2015 10:55 AM
myfirstxtypejag
Mar 7, 2013 02:05 PM
Mazaniac
Oct 23, 2008 02:25 PM
