X-Type 2006 diesel Start Problem
Hallo and Greeting to every one in this Forum ,
i have problem when the Car is cold start fast but when i drive for late say 5 Km and stop if i try to start the car its difficult need time to start ..i thought from the Battery i change it but still the same problem if somebody know the reason of this problem ... thanks
It might be a weak fuel pump. Diesel is more viscous than gas so that is a common problem with diesel cars. When it is cold the diesel is even more viscous which I'm guessing is why you are having trouble starting it cold. Otherwise it could be that you do need a new battery, you can go to you local parts store and they can check your Cold Cranking Amps of your battery. I hope this helps👍
zibby_uk
Jul 18, 2011 11:12 AM
