X Type 3.0 automatic slipping in 3rd
Old Apr 21, 2013 | 04:48 AM
Tomostrash's Avatar
Default X Type 3.0 automatic slipping in 3rd
Hi I don't know if you can help but i have an xtype 3.0l 2001 and the auro box is slipping in 3rd gear,ive flushed and renewed the oil,tested and cleaned the earths, checked connections to ecus and gearbox but they look ok.
Ive plugged it into a scanner and a fault of incorrect 3rd gear ratio is coming up.
Ime suspecting box internal problems and ime thinking of checking the control solenoids does any one have any information that may help.
Regards Tomostrash
Old Apr 21, 2013 | 06:20 AM
Welcome to the forum Tomostrash,
I've moved this post to its own thread and deleted your duplicate in Jaguar Forums Advice / Feedback & Suggestion Center section. This is the place for questions about your model.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST section and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice on posting to the forum.
Old Apr 25, 2013 | 04:27 PM
Tomostrash's Avatar
Default x type slipping in 3rd 4th 5th but reverse ok
I found the problem it wes the high clutch friction plates only cost Ł85 to repair and quite easy to fit if your willing to try.
Old Apr 28, 2013 | 05:34 PM
Dennis Vargas's Avatar
HI i have a jag x-type 2005 and it show me a message ¨gearbox fault¨ i recently change the transmition oil ... may someone tell me what to do?
Old Apr 29, 2013 | 04:43 PM
Tomostrash's Avatar
You realy need to get the codes read from the ecm and gearbox before you dive into any self diagnosis as this will save time and money.
JarodL
Mar 7, 2024 01:39 AM
way2far
Aug 31, 2022 09:26 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
David Thompson
Sep 3, 2015 07:48 PM
dcvickers
Sep 2, 2015 06:14 PM
