x-type
Old Nov 18, 2010 | 07:23 PM
diggerdegraves's Avatar
Default x-type
I went to look at the faq but i am not able to view as i am a new member.
let me ask a quick question, I have to replace 2 studs on the rear hub. long story, my wife hit a curb and the lugs were on so tight that i snapped 2 studs trying to remove the broken wheel. as it was windy and 30 degrees out i was not happy. I'm looking but i cant figure out the stud size, any ideas?
Old Nov 18, 2010 | 07:28 PM
Hey Digger, welcome to the forums, good to have you here on one of the friendliest sites around!
There's some great members here, techs are the best and always plenty going on.....check out the off topic section / detailing section and regional sections too!
I've manually upgraded you to Full forum access so you can better enjoy all the sites features
Get stuck in to that FAQ.......
Old Nov 18, 2010 | 07:36 PM
Default x-type
thank you for the help.
Old Nov 18, 2010 | 07:38 PM
krisleslie's Avatar
Jim is always helpful too
Old Nov 18, 2010 | 07:40 PM
cheers Kris .....I'll pay ya later as agreed
Old Nov 18, 2010 | 07:46 PM
krisleslie's Avatar
Hahaha anytime bro
Old Nov 18, 2010 | 08:29 PM
Default xtype
i read through the faq's and i still cant fint the stud size for the hub. do i have to replace the entire hub and bearing assembly?
Old Nov 18, 2010 | 08:32 PM
sorry digger, I thought it may have been
Hopefully Thermo / Buck / or one of the switched on Xtypers will drop by and help out.....In the meantime we'll BUMP this thread for max exposure.
Good luck
Old Nov 18, 2010 | 08:38 PM
thanks, i'm not sure i want to trust the 19 year old behind the parts counter when they have already given me the wrong set of spark plugs and stated that no one has ever asked for jag parts before..lol
Old Nov 18, 2010 | 08:42 PM
digger, please do yourself a favour and check out our vendors section....We have some excellent Jag specialist vendors who have a great name for price / service and reliability on site for supplying a wide range of spares.
I'm positive they could sort you out with what you need very quickly
Old Nov 18, 2010 | 08:50 PM
that will work for future parts.... but i have to get the car road ready by this weekend. in iowa i have a jag dealer that has to order parts or a local parts store, limited options for a quick repair
Old Nov 22, 2010 | 12:02 PM
lightninfil's Avatar
jag part number c2s50885 and it says its m12 x 42mm. hope this helped.
Old Oct 16, 2011 | 10:19 AM
Default x-type coolant issue
good morning all, its been a while since i've been on. two teenaged girls, i have to fight for computer time in between running them all over town.
also the jag has been in the body shop for a couple weeks thanks to a work truck backing into me, about 5 grand in damages. i will try to post a pic.
i do have a guestion about my 2002 x-type 3.0
i had a leak in the coolant tank and replaced last year. replaced with a used one as it was all i could find at the time. i has now started leaking. i found a new one to replace it with, but before i do an damage another one, is there something i should look for as the cause or is this something that happes often. i did see the same stress fractures on both tanks in the same places- right on the inner seal were they are joined.
what do you think.
Old Oct 16, 2011 | 10:58 AM
Thermo's Avatar
Veteran: Navy
digger, unfortunately, that is a design flaw of the tanks. The only "fix" (use this term loosely) that I have heard of is people have used a drill and gotten rid of the piece on the tank and then went out and bought a brass bar piece to slide in there in place and then used some epoxy to seal things back up. Not sure how long it would last, but so far things seem to be holding out.
The other option you can try (not sure how it would work) is to get some thin super glue and epoxy. Then at each end where the crack is just starting, drill a small 1/16" to 1/8" hole to stop the crack from going any further (stress relief hole) and then use the epoxy to fill that hole. Then you can stress the tank just slightly to open up the crack and put a drop after drop of the super glue along the crack until the superglue has filled the crack. The superglue will wick along the crack due to capillary action (hence why I talk about the thin superglue).
Hope this helps you get things figured out. May want to try it on an old tank first to get the hang of what is happening here. That way if things go south on you, you are not out anything.
Paora
Feb 4, 2021 12:36 AM
Msteiner
May 16, 2016 12:19 AM
jospolice
Oct 2, 2015 07:16 PM
millertic
Sep 30, 2015 08:11 PM
