X-type is completely dead.
Old Oct 26, 2015 | 02:54 PM
alclarkey's Avatar
Default X-type is completely dead.
So I'm idling the car for a while, and it shuts off and won't start back up. Put the battery on the charger, able to start the car afterward, so ok must be bad alternator. Replace the alternator. Car sat for several weeks. Car will not turn over now. Recharge the battery, still will not turn over, retry it several times, and finally it turns over for about a microsecond, now there is no power to anything, where the accessories worked before. Nothing completely dead. I'm banging my head against the wall with this car. Any help would be appreciated.
Old Oct 26, 2015 | 03:01 PM
Bud Tender's Avatar
Did you check both ends of both battery cables? The ends not at the battery have been known to go bad.
Old Oct 26, 2015 | 04:59 PM
Dr dome's Avatar
If the battery is not holding a charge the battery could be bad. Have it checked. If its more then 3 years old my guess is. The battery was your issue the whole time
Old Oct 26, 2015 | 08:04 PM
alclarkey's Avatar
I should have mentioned, after finding out the car was dead, I went and got a new battery for it. The old battery was definitely bad, it was tested 3 times. Put new battery in. Still nothing, deader than a door nail. I suppose it could be a bad connection, but the clamps made a good spark when I connected them to the battery. I guess I'll check those connections out tomorrow.
Old Oct 28, 2015 | 09:54 AM
dwclapp's Avatar
+1 re: checking the battery cables. Some corrode internally. Also, clean the connection where the negative battery cable bolts to the chassis ground. It's below the battery, between headlight & wheel well.
Old Oct 29, 2015 | 08:57 PM
sidct's Avatar
Most like bad battery cables, common problem with x-types.
Arkkitehti
Nov 19, 2015 07:09 AM
TweeTwee
Nov 10, 2015 01:56 AM
AnD3rew
Oct 28, 2015 10:22 PM
djpxk8
Oct 26, 2015 01:32 PM
Jagzzz
Oct 26, 2015 11:46 AM
